E4od no lockup - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 01-21-2008, 11:30 AM Thread Starter
joh
E4od no lockup
My lockup suddenly stopped working.I have now tried to put on a switch on the TCC wire and the solenoid is working great.(I can hear clicking).But when I drive there happens nothing when I engange it.Computer is throwing code 62.I have now driven about 100miles with the od light flashing,and the rest of the gears seems to be ok.Is it possible that I have blown the oring in the converter?Have anyone had anything like this?
joh is offline
post #2 of 18 (permalink) Old 01-21-2008, 01:33 PM
Mark Kovalsky's Avatar
My Photos: (6)
It could also be a stuck valve. The solenoid doesn't feed the torque converter directly, it controls a valve in the valve body that feeds the torque converter. If that valve sticks you'll have this problem. I think it is more likely than the seal ring, which is also a possibility.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #3 of 18 (permalink) Old 01-21-2008, 08:28 PM
cdnsarguy's Avatar
My Photos: (109)
For a code 62 I would first advise checking all connection to the trans........
Check all the trans electrical connections especially the one on the right side with the tin cover, remove the tin heat shield, remove the solenoid connector by pushing on the center tab and pulling up on the wire harness. To install push down until a click is heard. Always reinstall the tin heat shield.
Your looking for corroded, bent or missing pins and water etc.......
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #4 of 18 (permalink) Old 01-21-2008, 09:52 PM
FraserScott's Avatar
My Photos: (17)
You may also have a bad trans oil temp sensor. This sensor prevents lock-up under a certain transmission oil temperature to prevent premature converter clutch wear. This sensor is located in the the valvebody. But like Cdnsarguy says, check the connections first. They are usually the root of the problem.
1990 F-350 XLT Lariat CrewCab 4X4, 7.3L NA IDI, E40D, 3.55, Rebuilt injection pump and injectors, Manually controlled TC, Fleetguard DC4A, 277,000 Kms, Two tone brown. Completely stock. 9200# GVWR. ***In the works of being converted to a ZF-5 with Luk Clutch/ Single mass flywheel conversion***
1986 F-250 supercab 4X2, 6.9l, T-19B 4spd, 3.55LS,8800# GVWR 200,000 kms.
1983 F-250 supercab 4X2, 4.9l, T-18 4spd, 4.10, dad bought it new, dark teal metalic, 317,000 Kms drivetrain all original. 8800# GVWR.
2005 E-150 XL, 7 passenger, 4.6l v8, 3.55 LS, Navy Blue. 44,000 kms.
FraserScott is offline
post #5 of 18 (permalink) Old 01-22-2008, 12:05 PM Thread Starter
joh
All wiring is ok.When engine is not running and ignition is on I can hear the solinoid click when I engage it with the manual switch,but when i drive there are no lockup when I trigger the switch.I still get code 62 even if the lockup wire is disconnected but I think this is because the computer belives that the TCC is engaged.I am ofcourse geting code (94) on the disconnected TCC wire.I belive that there are pressure loss somewhere
Thank you for answers
joh is offline
post #6 of 18 (permalink) Old 01-22-2008, 01:27 PM
Bill1013's Avatar
There is a plug on the drivers side 6" forward of the shift lever on the bottom just above the pan for pressure checks, I think it's 1/8th pipe plug. In park you should have 55 - 65 PSI 379 - 448 KPA. With wheel jacked up and in drive, rev engine up with brake on pressure should increase to around 130+ psi, at least it should increase. Check the blue wire on the tranny for ground -- should be 20 - 30 ohms resistance. TOT check-- Warm fluid 21-40 C or 59 104 F resistance should be 16 to 37K as temp goes up resistance goes down. Check is across both yellow wires. If your fluid is high it might be foaming, causing low pressure. As others have said, could be sticky valves, found sticky valves in my tranny for about the same problem as you are having.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #7 of 18 (permalink) Old 01-24-2008, 04:17 PM Thread Starter
joh
Did check the pressure today and it looked good.The only thing I noticed was that there were difference in the pressure.1 and reverse did have higher pressure at idle than 2 and Drive.other than that it seemd ok.Where are the valves located?
joh is offline
post #8 of 18 (permalink) Old 01-24-2008, 04:55 PM
ltaylor's Avatar
Just something to eliminate, make sure you don't have a burnt out tail light/ brake light. Normally it will only unlock the converter if your lights are on and you apply the brakes but I've seen stranger. Les
2001 Excursion Limited, 4x4, toreador red, 4" turbo back exhaust, DYI Tymar intake,V's & modded B's, 30mm rear sway bar,
203 deg T-stat, alum housing, coolant filter, all from Bob Reilly
formerly known as; pullmyfinger
ltaylor is offline
post #9 of 18 (permalink) Old 01-24-2008, 04:58 PM
ltaylor's Avatar
you have to remove the pan and they are located in the valve body. which would be the next item you could remove from inside the tranny( besides the filter)
ltaylor is offline
post #10 of 18 (permalink) Old 01-24-2008, 06:28 PM
Bill1013's Avatar
If you are going to work on the valves , it's a very messy job. But here's how.
Put truck on hoist if available, if not, jack it up high as possible (front & rear) support it well on (jack stands)or blocking. Put plenty of cardboard under truck.
Drain the fluid, drain plug, great, no plug, remove all pan bolts except 2 in front and 2 in rear, have large enough container to catch fluid, (40 gallon storage container works), loosen front 2 bolts 1/4" to 3/8" some fluid will drain, carefully loosen rear 2 until fluid starts to drain, you will catch on how. Remove pan & filter. Let drain for a couple hours.
Remove control body assembly, 14 bolts 8mm socket, 2 nuts 10 mm socket. More fluid draining, down your arms.
See if any valve is stuck out of position. With very small screw driver or pick you can move the pistons to see if they are free, move both directions. Click image to open and print out. At least this will show what valves are what. Above all make sure you keep everything CLEAN.
Bill1013 is offline
post #11 of 18 (permalink) Old 01-26-2008, 12:19 PM Thread Starter
joh
No sticky valve,only a broken spring in the intermediate clutch accumulator.Now I am going to cut open the TC,because I found some black material in the filter that I belive must come frome the TCC.I have a old one that i did open to check how the TCC works and the friction material looked just like what I found in the filter.
Thanks for great help.
joh is offline
post #12 of 18 (permalink) Old 01-26-2008, 04:03 PM
cdnsarguy's Avatar
My Photos: (109)
Solenoid body torque specs are......9-11 newton meters or 80-100 INCH LBS (NOT foot lbs)
There are 12 INCH pounds to 1 FOOT LB...... 80-100 inch lbs = about 8 foot lbs max.
post #13 of 18 (permalink) Old 01-30-2008, 02:54 PM Thread Starter
joh
It looks like it was the torque converter that was the problem.I changed it and my lockup came back.I just wonders why the lockup went from fully working and no slipping and next minute it was gone.
joh is offline
post #14 of 18 (permalink) Old 01-30-2008, 04:28 PM
cdnsarguy's Avatar
My Photos: (109)
So to change the TC you would have to remove the trans right....... may have only been a bad electrical connection somewhere. Check the brake light switch on the pedal too, there have been reports of a bad switch flickering on the brake lights which will unlock a TC every time..
post #15 of 18 (permalink) Old 01-31-2008, 05:25 PM Thread Starter
joh
There were no bad connection.I cut the TC open today and found a big bit of the lockup clutch material were gone and there also were a broken bolt (its really not a bolt but its hammerd on both side dont know what you call it).I gues this broken bolt have messed up the clutch.
joh is offline
Similar Threads
E4OD Harsh 3-4 shift/ Torque Convertor Lockup jeffrall 7.3L IDI Diesels (Not Power Strokes) 3 03-08-2007 11:40 PM
T/C lockup JPLTrucking '99 & up 7.3L Power Stroke Engine and Drivetrain 6 12-27-2006 02:26 PM
so how does a t/c lockup frashdog '99 & up Upgrades and Aftermarket - 7.3L Engine 28 04-02-2006 07:46 PM
E4OD TC Lockup when stopped. OD Light flashing. 67Racer 7.3L IDI Diesels (Not Power Strokes) 3 08-29-2005 11:09 PM
4x4 E4OD to 4x2 E4OD future_stroker Power Strokes 1994-1997 Upgrades and Aftermarket 3 07-31-2005 12:14 AM
