e4od transmission problems - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 02-23-2010, 06:01 PM Thread Starter
hello,
this is my first post so sorry if im int he wrong place. i recently got a 1992 ford f250 7.3L idi with the auto e4od tranny. the transmission is toast, so on searching craigslist i found one out of a 1995 powerstroke pretty cheap. my question is will this one work in my truck? im not sure if it being out of a powerstroke makes it any different.
1992f250idi is offline
post #2 of 20 (permalink) Old 02-23-2010, 07:01 PM
Plywood's Avatar
My Photos: (13)
Wouldn't quite be a direct swap to a non-turbo, the ecm would be different if nothing else.
The most straight across swap would be from, I think they start in 88 or 89 and go up to 94. A truck with an IDI non-turbo will be the easiest if yours is a non-turbo for sure. Also seems like I've read they are stronger starting in 93 or 94.
You could do a C6 if money is tight and you want less problems in the future and are willing to give up the overdrive. You would however have to add the VRV to the IP and a couple of vacuum lines down to the tranny but I'm sure that could all be had at a Pick and Pull or something.
85 F250 XLT Lariat 4x4 7.3L N/A, C6, 315/75/16 Siped Wild Country Muds, Manual ZD9s, K&N, Soup Bowl Out, Dura-Lift Pump, Dynomax 3" Y-pipe-4" AFE Muffler-5" Turndown.
Turn it up!
Plywood is offline
post #3 of 20 (permalink) Old 02-23-2010, 07:19 PM
rsr911's Avatar
Should be a bolt in but you'll need to change the connectors on your harness. Both the solenoid pack and MLPS connector will be different. I think the '92 had the electronic speedo. The newer trans don't have the drive gear for a cable driven speedo and VSS sensor. Check to see if yours has a cable for the speedo, driver's side tailhousing. If it doesn't then you're in luck there. I have a '99 trans in Michigan, from the pictures my brother sent me everything will bolt up to mine. I currently have a '94 rebuilt trans in my van. I had to change the connectors and wire up a speedo from a '93 van then tap the rear axle VSS signal to send to the PCM. You should be able to use your current TCM.
1986 F350 Crew Cab 4wd DRW conversion. 1993 7.3 IDI, 5spd Sterling 10.25 4.10 rear, kingpin D60 4.10 front, 12" HD clutch. A Banks waste gated turbo. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W80-W85 high performance zero-gel black diesel! 4wd and dually conversion is done. Washer mod on the D60 kingpins eliminated the death wobble. Custom 10" C-channel front bumper with military D-rings front and rear. Pintle hitch, receiver hitch, and goose neck hitch. 7800lbs full of fuel....
rsr911 is offline
post #4 of 20 (permalink) Old 02-23-2010, 09:53 PM
cdnsarguy's Avatar
My Photos: (109)
Give us a hint as to what your problems are........... have you got any code numbers yet.
Codes are on my photo link....... autozone and other AP stores will check your codes....
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #5 of 20 (permalink) Old 02-23-2010, 10:00 PM
johnboggs21's Avatar
make sure when you pull the codes you do it with the throttle to the floor, otherwise you will get the code for TPS out of range
1993 F-250HD 7.3L IDI E4OD 370,000 miles Now sporting a strait pipe and has the soup bowl mod.
I'm gonna sign my name in that diesel smoke and let the ones that come along behind me choke!
johnboggs21 is offline
post #6 of 20 (permalink) Old 02-23-2010, 11:20 PM
Plywood's Avatar
My Photos: (13)
I guess I said ECM instead of TCM but since you have to change it to go from N/A to turbo, I'm pretty sure a powerstroke TCM would be different than an IDI non-turbo if it really is a non-turbo. Seems like a DI TCM would be different than an IDI TCM due to power differences and such but not sure about that.
Turn it up!
Plywood is offline
post #7 of 20 (permalink) Old 02-24-2010, 01:46 AM
rsr911's Avatar
On the IDI the TCM only controls the transmission. The sensors on the engine are only to provide input to the transmission control module (TCM). At worst case he would have to swap the solenoid pack out of the current truck into the new trans. I don't know what year but at some point some diodes were moved either to or from the TCM that were on the solenoid pack or the other way around. If the current trans is mechanically toast then the simplest option is to swap solenoid packs and the MLPS that way the harness wouldn't need changed.
I'm sure Mark will chime in at some point and correct me if I'm wrong.
The '99 trans I have in Michigan has the driveline parking brake which means it has the correct tail housing for 4x4 should my plans to install my motor into an older crewcab 4x4 ever come through. Anyway I had my brother who has that trans take a ton of pictures for me so I could compare to my burnt up trans and sure enough it looked like the plugs on my '94 trans. The bell housing bolt pattern and shape looked the same as well.
His '92 should have the electronic speedo which makes that part a non-issue.
rsr911 is offline
post #8 of 20 (permalink) Old 02-24-2010, 09:57 AM Thread Starter
ok so it will fit but i may or may not have to change the connectors? also, if i were to do a c6 swap what c6 would fit, im looking on ebay and the only ones i see are small block or big block gas jobs nothing for the 7.3 diesel.
post #9 of 20 (permalink) Old 02-24-2010, 03:16 PM
im pretty sure an C6 will work but you need the diesel bellhousing.
post #10 of 20 (permalink) Old 02-24-2010, 06:50 PM
rsr911's Avatar
C6's have an integral bellhousing, you would need a diesel specific one. You would also give up OD. The E4OD is a good trans if the sensors are maintained and codes scanned in my opinion.
rsr911 is offline
post #11 of 20 (permalink) Old 02-24-2010, 06:53 PM
you can get a gearvendors unit if you want your OD back. Or you can run a brownie box behind the tranny
post #12 of 20 (permalink) Old 02-24-2010, 08:45 PM
Plywood's Avatar
My Photos: (13)
It's been reported you can use a C6 from a 460ci truck, but that you have to drill a hole or two and that it is a pita.
Turn it up!
Plywood is offline
post #13 of 20 (permalink) Old 02-24-2010, 09:03 PM
Originally Posted by 1992f250idi View Post
hello,
put in your avatar where your from--------someone might be close to u with a good used one----
94_turbo is offline
post #14 of 20 (permalink) Old 02-25-2010, 06:15 AM Thread Starter
i think im going to keep my e4od, i want the truck on the road asap so its easier to keep it as is. i read somewhere that if your truck wont move in 1st but will if you put the lever in 2 it could be your solenoid pack is that true? also, im in the northwest corner of CT
post #15 of 20 (permalink) Old 02-25-2010, 08:18 PM Thread Starter
does anyone know what it means if i have movement in 2 but not in 1 or drive? if i start and two then upshift to drive it will shift into 3rd fine but then i dont have overdrive. does this mean my transmission is mechanically toast or could it be something easy like the mlps or solenoid pack?
