Old 01-15-2006, 08:31 AM   #1 (permalink)
E4OD transmission swap options
I couldn't find the answer when searching this forum . I am going to replace my 1994 F250 E4OD with a used transmisson and want buy the right one . Are all E4OD transmissions the same ? What source of E40D and TC will work in my (all models please cars,trucks,gas,diesel )- Thanks
1994 F250 7.3 IDI E4OD
rkpatt is offline
Old 01-15-2006, 12:58 PM   #2 (permalink)
My Photos: (17)
Re: E4OD transmission swap options
Haven't we talked about this? Didn't you just have your E4OD rebuilt recently? Spend the "used trans money" to buy the Baumann TCS @ www.becontrols.com , you'll be glad you did. OkieGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 01-15-2006, 01:15 PM   #3 (permalink)
Since the E4OD has an integral bellhousing, the only thing that will bolt up is from a 7.3L diesel. 89 - 94 is a direct bolt in, 95+ uses a 6 stud converter.
The biggest bolt-in change over the years has been the solenoid pack, I believe that was in 95. After my first "good used" E4OD failed in under a month, I went to Ford and got a reman which is a newer case and parts with the proper solenoid and converter to work with the IDI.
ALSO, before you replace the trans, check all your sensors and connections. These transmissions are electronically controlled and shifted, and if you bolt in a new trans to a bad sensor, it will not work right either. A bad sensor will kill a new trans just like it will an old one.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 01-19-2006, 06:23 AM   #4 (permalink)
I am a little confused - Do you mean that the 89-94 bell housing is the only one that will fit ? Or will the 95+ fit with a change to a the 6 stud converter ? - Thanks
rkpatt is offline
Old 01-19-2006, 10:11 AM   #5 (permalink)
you can use the 95-02 i think, any diesel E4OD or 4r100. 95-02 you will need to use an idi torque convertor and selinoid pack.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 01-19-2006, 02:32 PM   #6 (permalink)
I had my old trans rebuilt a year ago and it was upgraded with all the "newer" internals, like the new styl sol. pack, new design pump, range switch, and also rebuilt the valve body and modifyed the TC lockup circut to lock up better. All this ran me 2000. but it was worth it because I now all the "old" parts have been replaced with better ones that shouldnt have the same problems. Oh yeah, it also has a billet steel torque converter with more clutch material inside for stronger TC lockup.
94 F-350 CREW, FACTORY TURBO IDI, 10PSI BOOST, 3in STRAIGHT PIPE EXHAUST w/ BANKS DOWN PIPE, K/N FILTER, AUTOMETER GAUGES, BUILT E4OD, 4.10 gears, 200,000MI. 6 245-75-R16 TERRA-TRAC M/T's 2-KC DAYLIGHTERS
Ironman03R is offline
Old 01-19-2006, 02:44 PM   #7 (permalink)
My Photos: (17)
So, what do we have to do to make a 6-stud TC work in a 89-94 E4OD. I haven't taken mine out so I don't know how the TC attaches to the engine. I'm getting a 'blank' trying to visualize the connection. Thanks, OG
Old 01-19-2006, 07:33 PM   #8 (permalink)
How about we put are our 4-bolt tc in the newer tranny or you could probably drill the new holes in the flywheel.
Allen
