Old 11-14-2007, 09:56 PM   #1 (permalink)
farmfuel's Avatar
EGT probe- does is wear out like a oxygen sensor?
My pump is pretty turned up, and my timing is dead on. I have a 57 trim compressor wheel (larger diameter wheel, less blades)...which makes me think that it's flowing more air than the stock Banks TE06H.
What I don't get is: even when pulling a car hauler up hill, the EGT's never get above 700* Is it possible that the EGT probe could be wore out? Gauge not reading correctly? Is it possible that the pyrometer lead is so long that resistance is building up? Keep in mind that I've cranked up the pump one flat past what banks reccomends. Thanks in advance for your take on this matter.
89 F350 SRW Reg Cab 4X4, 3.55:1, ZF-5 w/ LUK single mass, added Banks sidewinder 12-06. So far so good. 17 mpg using B50 bio blend.
farmfuel is offline
Old 11-14-2007, 10:06 PM   #2 (permalink)
Send a message via AIM to VD350
Re: EGT probe- does is wear out like a oxygen sensor?
Where is your probe located? Before or after the turbo?
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 11-14-2007, 10:08 PM   #3 (permalink)
farmfuel's Avatar
I forgot to tell you that the truck is a smoker starting out in second, but doesn't smoke in any other gear. The only time I see it smoke is when I leave a red light. (smoked a lady behind me out pretty good one time; had her tell me that my truck needed a mechanic!) HA!
farmfuel is offline
Old 11-14-2007, 10:10 PM   #4 (permalink)
farmfuel's Avatar
The probe is just before the flange where the turbo bolts up.
(before the turbo)
farmfuel is offline
Old 11-15-2007, 12:39 AM   #5 (permalink)
arthurgoboom's Avatar
That sounds about right. The highest I've ever seen out of mine is about 625, and I see a light haze of smoke at the worst. Do you have the Sidewinder kit or the old non-wastegated like mine? The non-w/g kit has about 3 feet of tubing between the exhaust manifold and the thermocouple, so they say we could show about a 300 degree drop from the manifold temps, which puts you at 1000. That's still safe. I'm not sure what the manifold setup for the Sidewinder is like.
I have a pyrometer gauge out of a Kenworth semi truck, and probably 5 feet of lead between it and the thermocouple.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 11-15-2007, 01:25 PM   #6 (permalink)
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
The length of the leads is intentional from the factory- do NOT cut it. The company has the gauge calibrated for the x amount of resistance of the thermocouple itself and the wire leads, which probably isn't much, but I still wouldn't advise cutting it.
Also, I wouldn't reccommend using different brand thermocouples and gauges.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
Member of Indiana Air National Guard 122FW MXS
asauer is offline
Old 11-15-2007, 02:58 PM   #7 (permalink)
farmfuel's Avatar
I was actually thinking about ordering an auto meter pyro gauge from summit; what do you see wrong with changing the gauge? Maybe order another gauge from Banks?
I found this whole wastegated sidewinder system(to answer your question, Arthurgoboom) in a junkyard for 200.00. I don't know the history of the thermocouple or the gauge, but I do know that the engine came apart, and chewed up the exhaust wheel pretty good. (this is probably why it was in the junk yard) I reused the thermocouple because it didn't appear to have any damage.
farmfuel is offline
Old 11-15-2007, 04:29 PM   #8 (permalink)
asauer's Avatar
I don't think you will be too inaccurate, but nonetheless it could be off. I would call autometer and ask them about it. I'm sure banks gauges are made by the same company as autometer...
asauer is offline
Old 11-15-2007, 07:55 PM   #9 (permalink)
get an isspro their awesome I have autometer in mine right now and it sucks my buddy got is isspro and his pyro is like a rpm gauge its senstive and fast. mine is so slow and its an autometer C2
92 F-250 with luk clutch, got 304,000 miles out of old motor, now have IDI out of a 94 With factory turbo. Bought and installed ATS Exhuast housing, wastegate, downpipe. Turned up pump electric fuel pump. Runs like a bat out of hell.
andre7910 is offline
Old 11-16-2007, 01:28 AM   #10 (permalink)
Reaction speed of a thermocouple (pyrometer probe) depends on how much shielding is around the actual joint where the 2 wires meet. All of the thermocouples designed for EGT use have a stainless steel shield around the outside, the thicker this is, the longer it takes for temperature changes to register. The upside is with a thicker shield you are less likely to melt the shield and spit it through the turbine wheel (if you have a turbocharger).
Old 11-16-2007, 07:27 PM   #11 (permalink)
Actually, a lot of EGT sensors have switched to Inconel (Alloy 600) which has a higher melting temp than stainless, so they can swage it down thinner for better response. ISSPRO advertises Inconel tipped thermocouples which may explain their quicker response time.
'88 F-250 7.3 IDI N/A, 4x4, ZF-5, 3.54, 285/75/R16 All Terrains, bowl removed, dual 2" custom exhaust with glasspacks (very unique sound)
'93 F-250 7.3 IDI N/A, future project
'88 F-250 7.3 IDI N/A, **spare parts**
'92 F-350 7.3 IDI ATS Turbo, 4x4, 4-door, ZF-5, 3.73, turned up pump, ISSPRO gauges, 6" I-beam bumpers, 35" Buckshot Mudders, custom 4" straight exhaust
'89 Bronco - future 7.3 conversion
faz_fordfreak is offline
Old 11-16-2007, 10:17 PM   #12 (permalink)
asauer's Avatar
Interesting...I did not know that. I don't like getting my motor anywhere close to being 'iffy' as far as nuclear meltdowns go...I want to be at a comfortable temperature...
asauer is offline
