Electric battery "idiot" light flickering - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 03-25-2006, 12:00 AM Thread Starter
The idiot light that looks like a battery is flickering on/off. The volt gauage shows good voltage. RPM doesn't seem to effect it. Batteries always have good charge. The alternator was replaced with a brand spanking new one about 18 months ago. Problem is getting worse. I suspect the voltage regulator.
Oh wise ones, what is your verdict?
1989 Ford F250XLT Lariat extended cab 4x4 w/ N/A 7.3L, C6, 120k miles, & FlexSteel seats. Stock right now, but have a used non-wastegated Banks Turbo sitting in the garage (trying to find the time to collect the parts and install it)
03/06 - Auto-RX done. Filter looked normal.
04/06 - Installed 100gal in bed tank for WVO.
11/06 - New rotors & pads
biosdude is offline
post #2 of 10 (permalink) Old 03-25-2006, 12:13 AM
PSDfreak's Avatar
Re: Electric battery "idiot" light flickering
You read my mind....I would check that voltage regulator...Do you notice any thing feeling amiss in the brake system.
-Casey
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
post #3 of 10 (permalink) Old 03-25-2006, 12:14 AM
I have a problem with the connector at the alternator. it isnt very tight, replaced it and no better. my light blinks once in a while but I think it is that, but dont listen to me, I replace my alt/reg every 6 months. no shorting anywhere, but I have a lifetime warrebty on the alt from checkers, could be the reason it goes out every 6 months, they got junk alt's.
in2fords is offline
post #4 of 10 (permalink) Old 03-25-2006, 12:34 AM Thread Starter
Only thing wrong with the brakes is that they need to be rebuilt! I'll go invest the ~$15 in a new regulator and see if that fixes it.
biosdude is offline
post #5 of 10 (permalink) Old 03-25-2006, 12:57 AM
I had the problem awhile back, and the only thing that resolved it was replacing the headlight switch and pigtail, which were melted.
New VR didn't solve the problem in my case.
Mike
Mike Lewis is offline
post #6 of 10 (permalink) Old 03-25-2006, 07:41 AM
There's a connector on the side of the alt with 2 wires, one of them provides the signal for the battery idiot light. Mine came loose a while back and I had the same symptom. I replaced the connectors and no more problem [img]/ubbthreads/images/graemlins/smile.gif[/img]
1991 F-250 7.3l IDI, ZF-5, 2wd, 3.55 gears, Pioneer PEH-3500 Stereo with XM Radio, Infiniti 5 1/4" speakers
jayf63 is offline
post #7 of 10 (permalink) Old 03-25-2006, 11:14 AM
Interesting, mine has done it since I put in a 100 amp alt. Thought it confused the old VR.
Dane
1988 F250 4X4 Super Cab ZF XLT (Gone-sold) 1994 F250 4X4 Super Cab E4OD XLT 7.5L
Dane Launius is offline
post #8 of 10 (permalink) Old 03-25-2006, 07:19 PM
Alternator light is controlled by the white/black wire which plugs into the end frame of alternator, also known as the stator lead. If light is on and charging voltage is normal, then this wire is the culprit. That circuit is the same since the 1960s.
alternator doctor
89 f-350 XLT cc, 4.10, E4OD, Banks Shift Comm. Warren reman. 7.3, US Gears Ex. Brake
Neal J. Moran is offline
post #9 of 10 (permalink) Old 03-26-2006, 02:16 AM
northerncrewcab's Avatar
-Casey
What would the brakes have to do with the battery light flickering? Hope that question isn't stupid.
88 f-350 4x4 crewcab 7.3L, Hypermax turbo, 4" straight pipe,5spd trans,4.11 gears ), no soup bowl,k&n air filter, .460,000 kms., 2" body lift , Luk single mass flywheel.
northerncrewcab is offline
post #10 of 10 (permalink) Old 03-26-2006, 11:48 AM
PSDfreak's Avatar
vacuum pump...when that pump goes bad the brake pedal is hard as a rock...
-Casey
PSDfreak is offline
