electric fuel pump - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 10-13-2006, 04:20 PM Thread Starter
electric fuel pump
Can anyone tell or send me to a good place for instructions for replacing my manual fuel pump with a electric one. I understand removing the old pump....but what is done with the hoses and what psi electric should i buy
94 F350 7.3D IDI 4Door Crew
zhowiez is offline
post #2 of 5 (permalink) Old 10-13-2006, 05:05 PM
cdnsarguy's Avatar
My Photos: (109)
Re: electric fuel pump
Holley red pump is mostly used, some use cheaper.
From a past post.....
I'm using an electric fuel pump and love it! Napa Balkamp Universal Fuel Pump Kit: Part #610-1050; ~$36 out the door; 4-6 psi at 35GPH. Put it on the frame rail, just after your fuel selector valve, and let it push the fuel to the Fuel Filter.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 5 (permalink) Old 10-14-2006, 04:56 AM
Where did you pick off the power for the pump ?
Anything special in the routing of the wire ?
Can you leave the old mechanical pump in place and just run the electric in series? (As long as it doesn leak)
1991 Ford SD Bucket Truck with IH 7.3 NA.(A185)
Trans "E" Axle "73" with OD
5KW 220-110 VAC Dynamote inverter/ Gast air compressor.
Retired Verizion splicing rig out of PA. 68k on the odd. 4+k on the hours./ Removed soup bowl. Replaced Injector return lines/ Changed out Glow Plugs (New BERU's)/Replaced accel pedal cable/ Rebuilt Acell pedal mounting./ New LED Tail-Stop lights.
There is a computer with LCD monitor in the cab and a WIFI network from the cab to the bucket for testing sites. A desktop shelf to work on. Rear view camera and monitor and sonar back up system.
Made and wired in a remote control for the boom.
D_Vrablic is offline
post #4 of 5 (permalink) Old 10-14-2006, 09:59 AM
cdnsarguy's Avatar
My Photos: (109)
Sent you an email, I think Okie gringo sent me the schematic contact him to explain it........
Never have both fuel pumps installed, install the electric close to the FSV.
post #5 of 5 (permalink) Old 10-14-2006, 11:18 AM
My Photos: (13)
If you want a serious electric fuel pump that will outlast a holly by a few forevers, pickup a Facet dura lift, facet part #40223, you can get them from a Carrier Transcold refrigeration dealer, Carrier # 30-01108-01SV
They are the stock fuel pumps on new reefer units and are designed to lift 10 feet straight up, so you don't have to crawl around rigging it down on the frame( and have more wires down there to get snagged on brush), you can mount it up under the hood high, and it has a water seperator and inlet trash screen on it.
Holly's are nice for racing, but for long term street use, they don't hold up, and unlike some other performance pumps, they cannot be rebuilt on the side of the road, like say a Mallory, the Holly's have to be sent back to the factory .
--------Robert
'92 F-350 Crew Cab dually,7.3 5 spd+ 3 speed Spicer 5831 Brownie, Solid Flywheel w 12 1/4" Kevlar Clutch, ATS turbo, Hypermax Cowl induction, MS Tech Fan Clutch, Custom Aluminum Rodney Red Radiator, 4" Exhaust, Air seat, Western Hauler bed.
RLDSL is offline
