Old 12-25-2007, 02:46 PM   #1 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
electric fuel pump differences
I am looking for a good electric fuel pump for my truck. I know i want a holley red. BUT...is there much difference in quality of procomp red and holley red? they say procomp has a holley design and they both have the same specs.
Whats your guys' opinions?
1997 F-350, XLT, dually, crew cab, 7.3 PSD, E4OD auto, B+W turnover goosneck hitch
http://community.webshots.com/user/91diesel
**91diesel AKA anthony2010**
http://www.youtube.com/watch?v=fe622W_yZcQ
16.66MPG
[IMG src=file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-9.jpg][/IMG]
91diesel is offline
Old 12-26-2007, 04:28 AM   #2 (permalink)
Re: electric fuel pump differences
Not quite the same spec's the holley 97 gph pro-comp 115 gph both at 7 psi.
97 dodge 2500 4x4 cc lb 12V auto 3.54 pillar gauges 215 nozzels
31'TT at 8000 lbs
94 explorer
shorthair is offline
Old 12-26-2007, 07:58 AM   #3 (permalink)
91diesel's Avatar
so should i just opt for the holley since its brand name?
16.66MPG
91diesel is offline
Old 12-26-2007, 08:32 AM   #4 (permalink)
ltaylor's Avatar
I bought the procomp pump. Been working great for almost a year now. My only complaint is this style of pump is very noisy.
Les
2001 Excursion Limited, 4x4, toreador red, 4" turbo back exhaust, DYI Tymar intake
92 F350 CC SRW,7.3 E4OD 4x4
4" lift 35" tires, 4.10, 4" exhaust straight pipe,
ATS nwg turbo, rebuilt and balanced, holley red, new IP & injectors, rebuilt heads by me
A pillar triple pod, auto meter phantom gauges,
pyrometer, boost, trans temp, oil pressure & water temp
future upgrades
formerly known as; pullmyfinger
http://community.webshots.com/user/pullmyfinger76
ltaylor is offline
Old 12-26-2007, 01:33 PM   #5 (permalink)
91diesel's Avatar
ok ill probably go with PC even if they are noisier they are cheaper.
Thanks!
16.66MPG
91diesel is offline
Old 12-26-2007, 01:48 PM   #6 (permalink)
I ordered a procomp "red" from a dealer on flea-bay for $48 last week plus I also ordered a rebuild kit for $13 more which is back ordered so they're going to ship both at the same time to cut down on the shipping $$$
31'TT at 8000 lbs
94 explorer
Old 12-26-2007, 03:28 PM   #7 (permalink)
ltaylor's Avatar
i should have added people with the holley pump say they are loud also. Apparently this style of pump is just noisy.
Les
future upgrades
ltaylor is offline
Old 12-26-2007, 10:29 PM   #8 (permalink)
k...was looking at this pump info for the holley red pump on a site that lists its specs...
it says its not suggested to be used w fuel injection systems--but we can use it????
also says it isn't compatible w methanol or alcohol fuels...what about homemade biodiesel???
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
-Soon to come-
Mid 80's front clip
Matching fender flares
Black paint job with chrome trim (fender flares, grill, bed runners, wheels, exhaust stacks, windshield trim, bumper)
2.5" leveling kit
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
GOTTA LOVE FORD MUSCLE
Cjhstang is offline
Old 12-26-2007, 10:33 PM   #9 (permalink)
91diesel's Avatar
ill tell you next year when i run straight wvo.
16.66MPG
91diesel is offline
Old 12-27-2007, 05:01 AM   #10 (permalink)
The problem with Holley pumps is they're built for racing. They were never intended for long term use. When my Holley folded, I went looking for something better , and found a Facet Duralift Facet Duralift
It's the factory pump for new Carrier Transcold and Thermoking reefer units and is designed for continuous commercial service, and can lift fuel 10 ft up so, unlike a Holley, it doesn't have to be mounted down under the tank level to function properly. I have mine up under the hood on the inner fender where it's easy to change the filter screen on it ( built in, another nice feature having that with it's own trash/water seperator bowl, makes main filters last longer and you don't have to worry about crud locking up the pump )
Cost is a bit more than Holley, but it's well worth it.
--------Robert
'92 F-350 7.3 5 spd, Crew Cab dually,ATS turbo, 4" Exhaust, Air seat, Western Hauler bed. My Gallery
RLDSL is offline
Old 12-27-2007, 03:06 PM   #11 (permalink)
My Photos: (10)
Noise?! You only hear it until the 7.3 is thumpin under the hood.
92 F350 XLT Crewcab dually, 204K miles ATS turbo, 3 inch exhaust, DPS IP & Stage 1 injectors, Holly Red pump, K&N, E40D, aux cooler, A-pillar guages, 410 limited-slip rear, Rancho 9000s, towing package, full running boards, mud flaps, 94' Ford (Alcoa) aluminum wheels, Predator camper shell, 200 watts of Sony/Boston Acoustics! Complete engine rebuild at 176k miles. Ford reman E4OD at 204k miles.
2001 Komfort 26FS
My Truck
Fozz is offline
Old 12-27-2007, 03:55 PM   #12 (permalink)
Where do you buy the Facet pump? I did a few quick searches on google & ebay and couldn't find much on the 40222 model.
1988 F-250 regular cab 2wd, 7.3 IDI, C-6 (SOLD!!)
1994 F-250 XL regular cab 2wd, 7.3 non-turbo, E4OD
Installed Bronco overhead console, Eddie Bauer dash trim and power door locks/windows, bucket seats, A-pillar gauges, Banks Trans-Command.
... finally getting close to installing Banks Sidewinder
Discbrks is offline
Old 12-29-2007, 09:02 AM   #13 (permalink)
My new PC pump showed up yesterday, included was a second pressure spring to change from the 7 psi default to 9 psi. Going to try to get the shop MT so I can get it swaped in this next week.
31'TT at 8000 lbs
94 explorer
Old 12-29-2007, 07:12 PM   #14 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: discbrks</div><div class="ubbcode-body">Where do you buy the Facet pump? I did a few quick searches on google & ebay and couldn't find much on the 40222 model. </div></div>
About the only places to find them easily is at Carrier Transcold, or Thermoking dealers
Part number is 30-01108-01SV from a carrier dealer ( facet part #40223 )
It was funny, when I went to the Carrier dealer, they don't have the Facet # so I had hi just look up one for a late model Carrier reefer unit, and he had the part in the computer, but it took him quite a while to find it in the parts room. Turns out they've never had one go bad and he had no idea where they were stashed.
Considering all the frozen and refrigerated carriers we have around here( this is chicken hauler central ), I figure that's a real good sign.
------------Robert
RLDSL is offline
Old 01-19-2008, 05:08 PM   #15 (permalink)
this is supposed to be an excellent pump. i just installed one and am satisfied with it so far. it will pump about 3 times the volume of the facet pump mentioned above and it has an internal screen filter and comes with a mounting kit with rubber insulators to cut down on noise and vibrations.
Carter Universal Rotary Vane Electric Fuel Pumps: CRT-P4601HP - summitracing.com
dave diamond
diamond35c is offline
