Good stuff! I'm also planning on a homebrewed fuel system, except the electric pump would be more of a primer pump with the help of a check valve... anyway, will standard steel braided fuel line and radiator clamps work in place of the steel line from the factory between the mechanical lift pump and the filter/separator base?
__________________ '88 F250 Lariat extended cab ?10,XXXmi, C6 Auto, 3.55 rear, 16" Aluminum Summit Racing Rims, LT235/85R16 Bridgestone Duelers, Sony Xplod CD Reciever, Mostly OEM replacment parts, for now...Lovingly named "Brownie" simply because its brown and a sweet ride .
I don't see why not. I have rubber fuel-injection hose from the stock lift pump to the filter base on my rig. Just have to change a couple fittings to accept the hose. Its a low pressure sytem so it doesn't need anything too radical. I'm not sure how well braided s/s lines seal on pipe nipples, though, I don't have any experience with that.
1993 F350 IDI Turbo
4x4 ZF Crew Cab Longbox
BIG SLOW LOUD STINKY
I have this pump from my former drag car: SX Performance Fuel Pumps Model 18203. This thing free flows ridiculous amounts of gasoline but when I set it up as a collection pump for WVO is slowed to a crawl, just something for you guys considering WVO in the future to consider. I'm gonna test it again on a low viscosity WVO blend that runs well in my van. I note that it now says not for use with ULSD fuel, I assume this is because this pump is lubricated and cooled by the fuel flowing thru it. Even regulated it's likely too much pump for a lift setup, it's got -10AN fittings (5/8"), when I street drove my drag car with a return from the regulator it would heat up the whole gas tank in 30 minutes of freeway driving to the track. I later moved it in front of the engine to keep the fuel lines as far away from the heat as possible and the heat problem went away. I have used the Holley Red in the past and even have one temporarily in my early 911, I hate them! They easily rust the pump vanes, require too much attention and are noisy as all hell. The one in the car is bolted to a piece of car tire and is still far too noisy. FWIW I'll likely use a Carter on my van in the future, I've had great luck with them in the past.
I am looking to install electric pump this week were is the best and easiest way to pull power from?
I prefer to use a relay, triggered by just about any of the key on items like the radio etc. Typically I'll install a rocker switch in that line giving me a simple hidden kill switch. Also while not necessary it is also nice to have a rocker from an always on source to the relay, this allows you to run the pump without the key on such as after a filter change or after refilling if you ran out of fuel etc. Make sure you have a good ground source for both the pump and relay. Using the relay means you won't draw too much power from whatever circuit you choose for a trigger. Run a separate positive directly from the battery to the relay and on to the pump. I like to grind a spot on the frame then drill and tap for a bolt to ensure a good ground. I can't tell you how many guys I've seen broken down because of poor wiring to pumps and ignition systems.
Thanks for the info I will start running lines today. I hate bringing lines into the cab but the kill switch would be a good idea. I thought about running out of the fuse box under hood to a relay with two switches one to bypass relay for constant on and one for complete shutoff.
02 Ford Excursion 7.3 powerstroke 2wd. Rancho RS9000, B100 summer, B50 winter
94 F350 Crew Cab 7.3 idi turbo, no muffler, B100 summer, B50 winter
Don't bypass the relay, just rig a switch to an always on power source to the relay, there's your always on mode. You can put the kill on the ground side of the relay. I like to use a 3 way switch with center off, one side to constant power and the other to key on power, this gives you all the functionality in one switch.
