Engine Oil Cooler parts?
I called the local Ford dealer and they wanted 77 dollars for O-rings and gaskets for the engine oil cooler. I thought that was high. I called International and they can not find the parts I need without the engine number. Does anybody know where the engine number is located. I gave they the numbers on the valve cover and the 7 digit number in front of the injector pump and the International dealer said that those numbers were not the ones they needed.
So, if anybody knows where the engine number is located or if they know the parts numbers for the o-rings and gaskets let me know. I am getting oil in my coolant, but no coolant in my oil.
I have a 94 F-350 with the 7.3Idi factory turbo. Not a powerstroke.
Thanks,
Bill W
956-350-3315
94 F-350 C/C 4X4 long bed, 7.3 idi Turbo Diesel. ZF-5, 6" lift 35x12.5x16.5 BFG'S. ATC Turbo Upgrade, ATS Intercooler, 4" exhaust. Under cab battery relocation. Open Airfilter. 2005 VW Rabbit Diesel TDI 5-speed, panzer plate.
