Engine rebuild kit for '94 7.3 idi turbo? - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 06-06-2012, 12:51 PM Thread Starter
good time charlie's Avatar
Hey guys, my truck threw what sounds like a rod bearing last week and I've looked and looked for a rebuild kit but no luck. Every kit I find say's (except for 93-94 turbo.) Need to get going soon so any information on rebuilding it would be appreciated. Thanks
Sent from my PC36100 using AutoGuide.Com Free App
1994 f250 7.3 idi, factory turbo, ext cab, long bed, 4x4, E4OD
good time charlie is offline
post #2 of 18 (permalink) Old 06-06-2012, 01:56 PM
chuckster57's Avatar
welcome to the Diesel Stop
Biggest difference in the N/A and Turbo 7.3 IDI is the exhaust valves when it comes to parts for a rebuild. Other than that you can use the bearings and such for any 7.3 IDI.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 18 (permalink) Old 06-06-2012, 04:17 PM
My Photos: (27)
When it comes to rings, the factory turbo IDI's have keystone rings and pre turbo engines don't. That's possibly the only difference that comes to mind in a rebuild kit. Wrist pins are bigger but pistons aren't part of a kit.
LMJD is offline
post #4 of 18 (permalink) Old 06-06-2012, 04:59 PM
I'll have to remember that tidbit about the rings.
Answered on my iPhone.
Train Horns:
post #5 of 18 (permalink) Old 06-06-2012, 07:02 PM Thread Starter
The exhaust valves I know how to go about but where would you guys recommend I get the pistons from?
post #6 of 18 (permalink) Old 06-06-2012, 07:33 PM
Since Mahle makes pistons for diesel engines. Might want to talk to them:
MAHLE North America | Aluminium pistons for gasoline and diesel engines
Train Horns:
post #7 of 18 (permalink) Old 06-07-2012, 12:50 PM Thread Starter
Alright, so the pistons and exhaust valves the only differences I have to worry about?
post #8 of 18 (permalink) Old 06-07-2012, 01:04 PM
My Photos: (27)
As far as we can remember. Don't take everything on an internet forum as the absolute gospel truth. After you decide what parts house you're going to buy from, the smart plan of attack would be to show the parts man your list of parts, then compare to see which turbo engine parts had a different part number versus non-turbo. In other words a rings set for both engines are going to have different numbers.
LMJD is offline
post #9 of 18 (permalink) Old 06-07-2012, 01:08 PM
Good advice. Also don't order any rings/pistons or bearings until the engine is torn down and precise measurements taken, ie cylinder taper, journal diameter, etc. You may find the pistons are okay and only need rings.
Train Horns:
post #10 of 18 (permalink) Old 06-07-2012, 01:11 PM Thread Starter
Alright, I checked into gettin the mahle pistons and republic diesel out here in louisvile has them so ill have them help me get everything I need. I appreciate the help guys, thanks
post #11 of 18 (permalink) Old 06-07-2012, 01:21 PM
My Photos: (27)
As Chuckster just posted (good advice again) I sure wouldn't order spendy pistons unless you check yours out first. By reading your first post, yours may be OK. Plus you don't know if you have standard or oversize bore.
LMJD is offline
post #12 of 18 (permalink) Old 06-07-2012, 06:11 PM Thread Starter
Yea, I will definitely tear the engine down and before I order anything. But since this is my first diesel and I've only rebuilt 350's and 305's in the past I wanted to learn more about it before I started on it.
post #13 of 18 (permalink) Old 06-10-2012, 08:13 PM
Hey if your looking for the gasket rebuild kit wise, i might suggest National Parts Depot. They have great parts at pretty good prices!!!! Best of luck on the rebuild!!
1993 F 350 Crew Cab Long Bed International Powered 7.3Liter IDIT, 5 Speed ZF-5 Transmission, 4.11 Gears, 4 inch lift with Humvee Military Tires, Bone stock other than that, goodies to come later!
Dtalbott13 is offline
post #14 of 18 (permalink) Old 06-12-2012, 06:35 PM
captpn's Avatar
My Photos: (6)
http://www.google.com/url?sa=t&rct=j...WxhYmnkNmv_T7Q
check out page 23.
if the link does not work, google
"939473IDITurbochargedDieselEngine"
and download the pdf...hope it helps, either way its a nice doc .
1994 F250 7.3 IDI Turbo SCLB XLT 2WD Auto, Silver/blue 146k (strange, but I like this one the most)
sold 2004 F250 CC 4X4 6.0 Lariat - born Apr/14/04
Camper pkg/ elect pedals/ 6 disk/ reverse sensor/ power slider/ chrome steps/ tint/ heated 40/20/40 /hitch / Arizona & Parchment /Revo 285s /cat-back / Bilstiens.
Ford Lemon / Replaced:
2003 F250 SC 4X4 6.0 Lariat - Born Dec/02/02 Camper pkg/elect pedals/6 disk/reverse sensor/chrome tube steps/heated captians chairs/hitch/Edge 2" leveling kit - White/Parchment - RIP
captpn is offline
post #15 of 18 (permalink) Old 06-12-2012, 08:54 PM Thread Starter
Thanks. I looked it over and that will help a lot. I appreciate it
1994 f250 7.3 idi turbo, ext cab, long bed, 4x4, E4OD
