Engine running temp? - Diesel Forum - TheDieselStop.com
Old 11-20-2009, 07:51 PM   #1 (permalink)
I recently took my truck on a long run (for me that is) and the temp gauge they usually runs on the low side of the dash gauge (just below the N on normal) now barely registers.
I pulled into the driveway leaving the engine running, popped the hood and used my thermal heat gun to check the upper radiator hose temp.
It was at 140 degrees.
I do know the cooling system is greatly over sized but do not think that 140 degrees close enough for the water coming out of the upper radiator hose.
Is the standard engine temp on these IDI Diesels supposed to be 180ish or not?
I thought I replaced the thermostat a couple years ago with the factory normal temp range and would just replace it, but it was not a simple 5 minute swap.
archangel is offline
Old 11-20-2009, 08:31 PM   #2 (permalink)
chuckster57's Avatar
I have an aftermarket gauge and the sending unit is in the D/S head between #6 & 8 and it reads @ 195 unloaded. your thermo might be stuck open, you may have a foriegn object lodged it it. Your post says you used the FORD/IH thermo right?
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 11-20-2009, 08:54 PM   #3 (permalink)
Originally Posted by chuckster57 View Post
I have an after market gauge and the sending unit is in the D/S head between #6 & 8 and it reads @ 195 unloaded. your thermo might be stuck open, you may have a foreign object lodged it it. Your post says you used the FORD/IH thermo right?
It was the stock replacement from a local auto parts dealer.
It's getting colder out and I need to decide what needs to be done before the temps drop hard and the snow starts falling.
So this weekend I am changing the oil and I guess the thermostat as well.
It should help the crap heater as well because it's losing a lot of air somewhere before it gets to the dash vents, and I'm unwilling to tear it apart right now.
Gray 1991 F250 standard cab, 7.3, E4OD, 3.55:1, stock wheels and tires.
Verified 19 mpg city taking off slow as hell the shutting down at red lights, and with the radiator grill blocked flush, no bed cover, "drag shoot" mirrors on I get 24 mpg at 50 to 55 mph on the freeway empty!
However, with a bed cover, no mirrors and Hydroxy
Old 11-20-2009, 10:12 PM   #4 (permalink)
RWF350's Avatar
I'd replace the t-stat and use motorcraft or IH.
2007 Chevy 2500HD 4WD Ext Cab (late model) 6.0L (gas) 6speed auto
Deceased--1990 F350 2wd DRW Super Cab E4OD 7.3l IDI
Gooseneck hitch, Flowmaster (single inlet/dual out), 60 gal tank/toolbox/bedrails/headache rack (custom built, welded together as 1 unit), 3 gauge pillar pod w/glowshift gauges, oil, water temp, trans temp
Never ask "What else can go wrong?" cause something will.
RWF350 is offline
Old 11-20-2009, 10:15 PM   #5 (permalink)
Search the IDI forum for P/N...IH/FORD thermo must be used...
Old 11-21-2009, 09:10 PM   #6 (permalink)
That might be my issue current issue and from day one it seemed to be running on the cool side, even with the grill blocked off.
Old 11-21-2009, 10:59 PM   #7 (permalink)
trampsdieseltruck's Avatar
My Photos: (33)
Motorcraft E5TZ-8575-C or Navistar 1807974C94 thermostat just replaced mine.ford was $34 + tax,int. $28 plus tax
1992 f250 7.3 nonturbo,4x4 360,000km,auto tranny
trampsdieseltruck is offline
Old 11-22-2009, 09:27 AM   #8 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Do the fan test on my photo link.....
Diesel engine coolant temperature at the top of the radiator where hose attaches after high rpm or under load condition for 20 minutes should be (195-237*F) 91-114*C nice time to have a temperature reading point and shoot tool.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 11-22-2009, 12:26 PM   #9 (permalink)
2nd that, they are the only good ones out there for our trucks. The off brands are crap.
1992 F350 Crew Cab 4x4 7.3l IDI E4OD No Turbo
1993 F350 Crew Cab 4x4 7.3l IDI E4OD No Turbo
1990 F250 Super Cab 2x4 7.3l IDI E4OD Utility bed
1987 E250 Quadravan 4x4 6.9 IDI C6 Banks Turbo, Gearvendor, and U.S. Gear Exhaust Brake
DragRag is offline
