Re: engine swap
Every thing will switch over. Injectors are the same. Pump is different. Wiring harness is the same as the late model 6.9's. I think the e4od should work to, mine was a C6 and every thing switched just fine.
One thing to consider, a lot of 6.9's had problems with the block cracking down by the starter frost plug, some can be fixed, many can't be. If I was going to do it I would sleeve a 7.3 and rebuild that instead.
Greg
1988 F250 7.3 diesel 4x4 auto C6 now ZF5
1990 F250 7.3 diesel 4x4 auto E4OD. now ZF5
1992 F250 7.3 diesel 4x4 ZF5
