Engine swap questions - Diesel Forum - TheDieselStop.com
Old 11-20-2012, 03:20 PM   #1 (permalink)
fourplayoffroad's Avatar
I was curious what is involved with swapping a 7.3 IDI with a zf 5spd into an 83 f350 that has a 460 in it. some Ahole backed into my 91 yesterday and took off while I was inside Napa. I can pick up this 83 f350 4x4 complete with bad engine for $1,000 and its in pretty decent condition, just not sure whats involved with the swap and the wiring. Thanks
fourplayoffroad is offline   Reply With Quote
Old 11-20-2012, 03:45 PM   #2 (permalink)
chuckster57's Avatar
The entire drivetrain, associated wiring, fuel system has to be brought over. If the 460 had an auto trans, then you need to install clutch components.
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline   Reply With Quote
Old 11-20-2012, 04:11 PM   #3 (permalink)
How much of the wiring do I need? Swap the tanks between the two trucks and what else? Sorry about the questions. I would do a search but I'm running short on time. Thanks
Old 11-20-2012, 04:17 PM   #4 (permalink)
The dash from my 91 should swap right into the 83 correct? If so then I could also swap the cab/engine wiring harness over too? In your opinion what would be the best and or quickest way to do this swap? It's my DD and I need it back fast because in the mean time I'll be driving my non street legal offroad rig.
Old 11-20-2012, 04:35 PM   #5 (permalink)
I am not sure what year the body styles changed, so I can't say for sure if your dash will move over. FWIW, I have managed to avoid these kinds of swaps for the duration on my career, so I only know what I have read on these types of forums. Sorry I couldn't be of more help.
Old 11-20-2012, 04:42 PM   #6 (permalink)
I thought the cabs were the same from 80-97. And that they just changed the styles of the dash. I could be wrong hopefully someone else will chime in soon and give some more insight on this. thanks for your input chuckster!
Old 11-20-2012, 05:39 PM   #7 (permalink)
stephencov's Avatar
If I'm not mistaken the cabs are the same, dash mounting holes are the same as well
stephencov is offline   Reply With Quote
Old 12-07-2012, 12:29 AM   #8 (permalink)
BUMP. I now have both trucks and have gotten the older truck cleaned up and ready to swap. can anybody tell me what I will need to do / swap to put my diesel in this truck? thanks
Old 12-07-2012, 03:43 AM   #9 (permalink)
drinkypoo's Avatar
My Photos: (23)
If you have to ask, 1) buy the EVTM 2) swap the entire harness
drinkypoo is offline   Reply With Quote
