I would try to find out if there is an airlock in the system......... engine off remove the coolant hose to the top of the water pump. try to fill it more.
When you had the thermostat out did you see a little check ball in the upper coolant manifold... see my pics. That little guy is for purging air from the system.... it should be there. One trick I use to find out if mine is working is on a cold engine, squeeze the upper hose fast and release.... do it a couple times and you should hear the ball rattle faintly.
Proud Canadian BOOB man too!!
