ether baby???? - Diesel Forum - TheDieselStop.com
post #1 of 25 (permalink) Old 01-21-2012, 11:05 PM Thread Starter
Lightbulb ether baby????
I just recently purchased a 94 7.3 idi, and after 2 new batteries, battery cables and a starter i found out the guy b4 me was starting with ether (everyday) is their any way to undo this???
stroke'm is offline
post #2 of 25 (permalink) Old 01-21-2012, 11:13 PM
chuckster57's Avatar
What are you trying to undo?
Any damage done, is done. If you mean it won't start without ether, then we can give you some pointers on diagnosing the GP's.
Sent from my Autoguide iPhone app
Train Horns:
PM please not visitor message
chuckster57 is online now
post #3 of 25 (permalink) Old 01-22-2012, 06:59 AM
trampsdieseltruck's Avatar
My Photos: (33)
have you tested your glow plugs?
1992 f250 7.3 nonturbo,4x4 360,000km,auto tranny
trampsdieseltruck is offline
post #4 of 25 (permalink) Old 01-22-2012, 11:02 PM Thread Starter
no i did not check them, but i just replaced them 2 days ago...
stroke'm is offline
post #5 of 25 (permalink) Old 01-22-2012, 11:08 PM
What brand did you install. So let me ask again: what are you trying to undo?
Do you mean the truck won't start without a shot of ether?
How long does the WTS light come on ?
Train Horns:
post #6 of 25 (permalink) Old 01-22-2012, 11:12 PM Thread Starter
it will crank with out it when it is still warm but once it get cold it wont start without it unless i plug it up (block heater) for half hour or so...found out this by going to a friends party(no where to plug up) was their for a few hours an it wouldnt start. shot a quick shot of ether ( per the guy i bought the truck from) and it fired right up... he then told me he was doing that ever since he had the truck, when it was cold out and had no where to plug in... i just knew it wasnt good for a diesel but didnt know what exactly it would do, one of by buddies told me it was like crack to a person, an if done long enough it would become dependent on it...
stroke'm is offline
post #7 of 25 (permalink) Old 01-22-2012, 11:14 PM Thread Starter
used motor craft, and depending on how cold it gets ranges from 20 to 45 seconds
stroke'm is offline
post #8 of 25 (permalink) Old 01-22-2012, 11:15 PM Thread Starter
just dont want to have to worry about if i go some where will the truck start or not...
stroke'm is offline
post #9 of 25 (permalink) Old 01-23-2012, 01:15 AM
There is something wrong with the GP system. Cold start should see the GP's energized and WTS light on for 12-15 seconds.
Train Horns:
post #10 of 25 (permalink) Old 01-23-2012, 05:48 AM
My Photos: (33)
used motocraft? if you dont have an ohm meter you can test the gp without removing them from the engine with a test light.like chuckster57 said sounds like you have a couple bad gp
post #11 of 25 (permalink) Old 01-23-2012, 07:01 AM
motor city 7.3's Avatar
Yep like trampsdiesel said,I had the same problem (cold starting) I checked my gp's and found one bad, replaced it and problem solved! You definitely need to check your gp's with a ohm meter It's super easy and while your at test the wires to. You can learn a ton around here just search the forum or ask these guys are awsome!
1993 ford f-250 XL 7.3 diesel 2WD reg. cab 219,000 miles and counting!
motor city 7.3 is offline
post #12 of 25 (permalink) Old 01-23-2012, 07:32 PM Thread Starter
ok thanks i will check them and get back...
stroke'm is offline
post #13 of 25 (permalink) Old 01-23-2012, 08:22 PM
Do not know if you are awear of this, " BUT " eather and glow plugs do not go well with each other.
2003 Ford F 250 Super Duty 4x4 6.0 Power Stroke auto, 132,000 miles
buckhunter1 is offline
post #14 of 25 (permalink) Old 01-23-2012, 09:30 PM
jacksonguitars4life's Avatar
yea if you got the gps working now, i would toss the ether in the garbage. one good puff and bang. ive heard of it blowing glow plugs to bits, blowing the prechambers out, and in one case a guy was diagnosing a no start after a head gasket job and it turned out he used the wrong bolts, so when it went bang it ripped the bolts out, and destroyed the threads in the holes.
93 F250 ext cab 4x4, 7.3 5 speed, Banks Sidewinder, straight piped
(I've actually seen people look up when I pass to find the low flying jet
) 2 tone beige (fugly) I dont worry about how much weight my truck will pull, I worry about how much it'll stop.
jacksonguitars4life is offline
post #15 of 25 (permalink) Old 01-24-2012, 04:32 PM
TXimport's Avatar
No disrespect to your buddy but a truck becoming dependent on ether is just rediculous!!! Its more like the driver gets dependent on it cause he doesn't know how or is too lazy to fix the real problem.
And yeah if you do ether wrong very bad things happen!!
BTW fixing the real problem with gp's is usually not very difficult.
So like the guys have said check the ohms on your glow plugs even if they are new even one bad can cause problems.
After that check your glow plug controller.
I think chuckster already asked but no answer ... How long is your wait to start light in the cab staying on when you first turn the key on?
This answer will tell us a lot and we can go from there.
SOLD!! 1993 F-350 XLT 7.3L IDI, Crew Cab, Long Bed, 2wd, 5spd, 3.55s, 173000 and rolling.
1994 F-350 XLT 7.3L IDI Turbo, Crew Cab, Long Bed, 2wd Auto E40D, 4.10s, 10.25 Ford Rear End 200k+ Puuurrring like a Kitten!!!
1999 F-250 Lariat 7.3L Powerstroke Crew Cab, Short Bed 4x4 Auto 3.73s, 340,000 on the clock. DIY Tymar Intake, Did away with 10k version 2 mod and Finally got a 5 position chip tuned and installed by Dirty Diesel!!
TXimport is offline
