Old 07-02-2005, 06:37 PM   #1 (permalink)
Excessive White Smoke / Rough Running
I have a 1988 7.3, and it sat around for about 3 months. I started it back up, and now it runs very rough, and puts out plumes of thick white smoke, even after it's warmed up, and even after I've put in some fuel system cleaner/water remover (I suspected water, but this stuff isn't helping at all).
Any ideas?
Thanks,
Skyler
2002 Dodge Ram 2500 Cummins 6-spd 4x4 - CTTD (Cummins Twin Turbo Diesel) - Stroker Smoker
1988 F-250 7.3 IDI Diesel 5-spd 4x4
SConklin is offline
Old 07-02-2005, 07:34 PM   #2 (permalink)
Re: Excessive White Smoke / Rough Running
I would be inclined to look at fluid level in the radiator.
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
Old 07-02-2005, 07:38 PM   #3 (permalink)
I'm new and also don't know squat about trucks, however I think you are saying that white smoke usually means radiator fluid is getting to the engine, and the way that usually happens is via a blown head gasket - is that correct?
dbk
1991 F-250 7.3L IDI,XL,5 spd, 4x2, 4.10, air horns, shell, 137K
dknapp is offline
Old 07-02-2005, 07:46 PM   #4 (permalink)
No, Maybe,
If you are losing radiator fluid, and it is a GOOD DAY, than it MAY a head gasket, if it is a BAD DAY...., a real BAD DAY, than it the big C.
But lets not go in that direction. Not yet.
Old 07-02-2005, 07:47 PM   #5 (permalink)
The big C being - Cavitation ....?
dbk
dknapp is offline
Old 07-02-2005, 07:50 PM   #6 (permalink)
Could be narley fuel?
We having a GOOD DAY, lets not swing the compass
Old 07-02-2005, 07:51 PM   #7 (permalink)
Amen to that - Happy 4rth!
dbk
dknapp is offline
Old 07-02-2005, 08:08 PM   #8 (permalink)
I would replace the fuel filter. While doing this, I would get a pint or two of Fred's hair tonic (Power Service, Stanadyne) and fill the fuel filter with it before you install it. Fire it up and cross your fingers. With hope, it will fix your problem. I'm thinking a bad or filthy injector or two. You haven't moved the injection pump, have you? Tim
'94 F250, 4X4, 7.3, E40D, 4.10, 126K
tim94f250 is offline
Old 07-02-2005, 09:36 PM   #9 (permalink)
bad IP pump will also do what you are stating. when the oring wear out, it will smoke like a bad dog. seen it more times than not. sniff the smoke while its running, dont inhale to deeply. if it smells like diesel, well thats an easier fix. if it smells like a case of burnt cookies, and makes you want to run and hurl, [img]/ubbthreads/images/graemlins/vomit.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img] it coolant. thats the best way to describe it..
huskyhauler is offline
Old 07-03-2005, 01:30 AM   #10 (permalink)
I have not moved the injection pump, or even the truck for that matter since it ran fine the last time.
SConklin is offline
Old 07-03-2005, 11:09 AM   #11 (permalink)
TorqueDog, check your PM's.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
