Old 05-25-2005, 11:47 PM   #1 (permalink)
Exhaust Break anyone? please advise
We are thinking about adding a exhaust break to our upgrade plan. . What are the current thoughts on this part. I know I woulden't have a Peterbuilt without one. Just wondering if anyone has used one on a F350.?.?...Is it worth it.? I know the breaks on my truck have always sucked-it can use all the help it can get.... [img]/ubbthreads/images/graemlins/tongue.gif[/img]
1994 F-350 XLT TURBO CREW CAB LONGBED 4X4- 7.3 IDI W/E4OD
flyingv is offline
Old 05-26-2005, 12:07 AM   #2 (permalink)
My Photos: (5)
Re: Exhaust Break anyone? please advise
Having owned an F350 CC Dually (The Enterprise) with a little extra fuel in the bed (119 gallons - like I said just a little [img]/ubbthreads/images/graemlins/wink.gif[/img]) I could not see the advantage to having an exhaust brake until.... I bought my new to me truck which has one installed by the previous owner. Now I'll never own another diesel without an exhaust brake. Man talk about nice - it sure is sweet. If I have to bring her to an abrupt whoa it can be done very easily - drop a gear, flip the switch and press on the brake - trust me you will find every last french fry from under the rear seat that used to be up against the rear wall of the cab. If I'm just doing normal driving and want to stop for a stop light I don't even touch the service brakes until I'm below 10mph - I can stop completely without touching the service brakes if I plan it right. Only problem is if the pavement is wet (during even a light rain) she will slow the rear tires enough that the rear end can scoot a little - not bad because the tires are still turning it's just that they are turning at a slower rate than needed.
Trust me you want the EB. You won't be disapointed.
Travis
Will Work For Diesel Fuel.
argve is offline
Old 05-26-2005, 02:55 AM   #3 (permalink)
speaking of exhaust brakes, does anyone know of a reputable manufacturer. I have looked at banks's stuff, and like it, but do they make a EB system for our trucks? I'm young and new to diesel trucks, but have helped maintained medium duty diesels on fishing boats, so i found word of mouth advertising to be the best.
--Ryan
91 f-350, dually, 7.3 diesel. 2wd, 4.10 gears LS. E4OD. New injectors, lift pump, and fuel filter at current 85,000 miles. Autometer pyro and fuel turned up. 3" exhaust with walker "btm" muffler
http://community.webshots.com/user/olivera_149
olivera149 is offline
Old 05-26-2005, 07:21 AM   #4 (permalink)
pontoonrob's Avatar
This exhaust brake works without changing out your valve springs.I have one and it works pretty good. It doesn't find old food though,like the goat boys. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] click here---Rob
l988 F250,4x2 XLT extended cab,-- 7.3,naturally aspirated IDI, 185hp,5speed gear rower, dueling pyrometers,-- persons+engine+gear=6990lbs!12-18mpg.
pontoonrob is offline
Old 05-26-2005, 08:38 AM   #5 (permalink)
My Photos: (5)
I run a Pacbrake brand. Also the other bennie to EB's is you can flip them on when you want to idle the engine to combat wet stacking and speed the warm up of the engine in the wintertime. Makes shorter work of defrosting the winders - I may own a scraper but refuse to use it - because it's cold outside.
Travis
argve is offline
Old 05-26-2005, 09:17 AM   #6 (permalink)
How does an EB effect a turbo? And if some EB need to have valve springs changed do the springs come with the brake kit? I sure would like to have a braking system I was confident in.
87 Ext Cab 7.3 4 speed.2wd will be 4wd as soon as I can find the right price dana 60.
wvwill is offline
Old 05-26-2005, 09:28 AM   #7 (permalink)
My Photos: (9)
Exhaust brakes are "oficially" not supposed to be used on hydraulic lifter engines but lots of people do without problems (especially Powerstrokes). Also the valve springs are the limiting factor in how much back pressure you can run. I am not aware of any valve spring upgrades for these old motors so you get what you get but something is definitely better than nothing.
Birken
Birken Vogt is offline
Old 05-26-2005, 09:50 AM   #8 (permalink)
Argve,
should one worry about overpressurizing his engine at high RPM? What about use with the E4OD tranny?? Now I don't want any trouble with dat ting. You have a standard tranny right?
>V<
flyingv is offline
Old 05-26-2005, 01:50 PM   #9 (permalink)
My Photos: (5)
Yep I'm bolt action in this truck so the effectiveness of the EB is more pronounced but I would not worry about it with the E4OD one bit the only thing that I would add is a feature where you can keep the TC locked up while the brake is engaged. I do believe that BD Performance makes a unit for the E4OD but you might want to check into it, because if you can keep the TC locked you will be very close to the operation of a stick on the slow down.
I have not heard of increased poundage springs for the IDI but Ken from DPS performance might have a bead on some or I would think he has looked into it since he is into things for the IDI that other companies have bypassed because of limited sales potential (he seems to be the only one in the world that can lay his hands on special items for the IDI).
Travis
argve is offline
Old 05-26-2005, 02:19 PM   #10 (permalink)
$1195. OOF! There's a kick in the nuts. I guess I'm not buying one soon.
Steve
Eric -> '92, F250, 7.3l IDI, extracab, longbox, one ton spring in the rear,Borg Warner 1356 transfer case, 12500lb winch. 280k km. Since purchased in June 2003 repairs include: ball joints, tie rod ends, all u joints, water pump, radiator, brake calipers, brake pads & shoes, rear drums, front wheel bearings & seals, rear axel seals, replaced transfer case, rebuilt rear differential, replaced bent drive shaft, replaced drive shaft support bearing, K&N air filter, dual 2.5" exhaust.
Mango is offline
Old 05-26-2005, 03:49 PM   #11 (permalink)
My Photos: (5)
Yes they are pricey but they are worth their weight in salt. You can find them used from time to time on flea bay. I seen one for sale on TDR that was an inline type (meaning could be used on anything with an exhaust pipe) for around 750 clams.
Travis
argve is offline
Old 05-27-2005, 07:53 AM   #12 (permalink)
pontoonrob's Avatar
[/ QUOTE ]when you buy a used one ,it needs to match your diameter of exhaust pipe.I bought mine used from a TDS member about a year ago,for $300.00 .What a deal,I had just changed to a 3" exhaust and it fit perfect. I don't think I would buy one if I had to pay over $1200. [img]/ubbthreads/images/graemlins/eek.gif[/img]---Rob
Old 05-27-2005, 12:16 PM   #13 (permalink)
My Photos: (17)
If I read the "de-cellerator" website correctly, the model for our IDI engines is $675 or $625, still kinda steep, but how steep is that mountain downgrade in front of you [img]/ubbthreads/images/graemlins/eek.gif[/img]? I'm trying to bamboozle 'management' into 'authorizing dispersment of funds' for one of these "De-cellerators". Ya just gotta use yer wits and clever cunning in this 'marriage game' [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. [img]/ubbthreads/images/graemlins/crazy.gif[/img]Baja
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 05-27-2005, 02:28 PM   #14 (permalink)
Listed on the DAS site under "Vaccum exhaust brake kits" they have a "6.9/7.3L idi Remote Brake Kit-3" Would that be an exhaust brake kit similar to the de celerator? ie. *** is the vaccum part?
Steve
Eric -&gt; '92, F250, 7.3l IDI, extracab, longbox, one ton spring in the rear,Borg Warner 1356 transfer case, 12500lb winch. 280k km. Since purchased in June 2003 repairs include: ball joints, tie rod ends, all u joints, water pump, radiator, brake calipers, brake pads & shoes, rear drums, front wheel bearings & seals, rear axel seals, replaced transfer case, rebuilt rear differential, replaced bent drive shaft, replaced drive shaft support bearing, K&N air filter, dual 2.5" exhaust.
Mango is offline
Old 05-27-2005, 02:37 PM   #15 (permalink)
Price code "B" (standard exhaust brake) is for power stokes and runs $675.
Price code "A" (Super duty wastegate regulated brakes) is for IDIs is $1195.
Steve
Mango is offline
