does anyone know where to get one of this. is the one between the manifold and the Y pipe.
thank you, exekiel
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights more pics BOOB Man
There is no gasket is between the exhaust manifold and the Y pipe, the only gasket is between the lower flange of the Y pipe and the flange of the exhaust pipe going to the muffler.........
If yours is leaking use some good old muffler cement and tighten it into place.
The Grey Beast. 90 F350 XLT 2WD 7.3L IDI, ZF5, Banks Pre-Sidewinder Turbo, straight pipe, custom tube rear bumper, RDT, Isspro pyro, boost, in a constant state of repair.
Muffler cement? What is it and where do I get it?
Duh, maybe at the "Muffler Cement Store", aka Autozone.
[img]/ubbthreads/images/graemlins/eek.gif[/img]Richard Cranium aka BajaGringo (sorry, I just couldn't help myself [img]/ubbthreads/images/graemlins/shrug.gif[/img])
E,
Might even just pain ole try to readjust the y-pipe a bit and retighten them there nuts down on the stud. If they have been off recently and not tightened properly, they can vibrate back loose to the point of leak.....Been there. [img]/ubbthreads/images/graemlins/bleh.gif[/img]
Goldie 1990 F-350 Custom 4x4 C/C DRW conversion. 7.3L Banks non-waste gated turbo, ZF-5 with 4" custom Exhaust complimenting a RDT venturi system, Autometer Pyro and boost 2 gauge pillarpod and your standard compliment of mechanical gauges. Clutch pedal Heim joint mod.
The Beef 1989 F-350 Lariat C/C DRW 7.3L N/A, ZF-5. Clutch pedal heim joint mod. Original price $500.00.
Currently slated for an extreme makeover ground up restoration.
Mater 2007 F-250 Lariat 4x4 6.9L IDI, T-19 trans pushing a 7'6" Western plow. Completely assembled from the tires up!
Hmmm... that might be my fault. I remember Eze asking me about an exhaust leak. Somewhere in the conversation I may have suggested there was a donut in there. I didn't really get a chance to listen to the leak. Eze, did our social secretaries set a date to come visit yet? I need some quality time with your truck to figure out that shake it has too. We should do it soon, while I still have the injector tester.
