Hello all I have a problem. the bolt near the firewall broke off on the pass side exhaust manifold going to the block. what is the best way to get whats left out. I havent taken it apart yet. 93 f450 7.3 none turbo. thanks Dean
1993 F450 SD 7.3 non turbo 5spd wrecker. 308K Miles, still going strong.just replaced injector pump & injectors, water pump. kailua Hawaii
Either way I would hose it down with PB Blaster and keep hosing it down... This stuff does wonders to rust.
If sticking out - yank manifold and get a good grip with a pair of vice grips then pour some heat on her and grunt...
Now if flush (if you luck it like mine it's either flush or broken down inside) then whip out the easy out (it's never easy and some one need to get a hold of the guy that named 'em that) - start praying and hope you don't snap the easy out. - fingers crossed for ya
Travis
Will Work For Diesel Fuel.
I've busted more Easy-Outs than had them work. Like travis said if you've got something left to grab on to, Vise Grip or I prefer a 6" pipe wrench- not as likely to slip. Either way, flush or stub left, like mentioned PB Blaster and it wont hurt to use a little heat (gentle now). Good luck,
Keith
93 F350 CC Dually 7.3 Hypermax turbo 4:10 gears, ZF rower, K&N filter, home made ram-air, Hypermax 3.5" exhaust, LUK clutch, 150,000 mi.
I have had manifold bolts break off from fatique and they were still loose in the hole when this happened so they were easy to remove. If you broke it trying to get it out then you may have to drill it out. Believe me you don't want to try to drill it out once you have broken an easyout off in the stud. I usually start with a small bit then gradually go to a larger bit. Usually the broken bolt will start to rotate with the drill bit before you get to a drill bit that is as big as the internal threads. Once you got it free by drilling, use an easyout to remove it. If you damage the threads getting the bolt out you can helicoil it. Most of the time a tap will clean it up. Try to make the hole as close to the center of the broken bolt fragment as you can, a center punch helps.
Perry
1992 F350 Crew Cab, 7.3l IDI, LWB, 4x4, E40D trans, 170,000 miles so far.
The manifold bolts on my 93 are ""factory special"" and have a triangular raised thread to lock them in place. This makes them a little harder to install and remove, it's like a lock nut effect.
Removing them will not be easy unless the shank is exposed. Couple suggestions:
If the shank is exposed use vice grips or weld a nut to the exposed end turn it out using heat.
If the shank is flush then drilling and an easyout is about all you can do...use reverse turning drill bits.
The exhaust manitold bolts have two types now OEM and updated.
OEM came with a special washer.
The updated bolts have a different head with the washer incorporated when checked they would be the same thread length so as not to bottom out.
New bolts are... F4TZ 9S425 B about $1.75ea
a recent broken headbolt by a 6.9 poster was very informative. The thing I learned is to make sure you center the drill hole or your toast. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Sold! 1986 F-350 XLT, Crewcab 4x4, converted to Dually, AT, Axle 39, 3.55 ratio, 7500lbs empty, aluminium wheels, K&N filter, rebuilt IP, and injectors, tach, trans oil temp gauge, chrome headers 2-1/2" exhaust to glasspacks to Magnaflow to 4" single, new headgaskets, new radiator, Mitsubishi starter, Big alternator, Big batteries, Racor R26S water seperator, Folding gooseneck hitch. 97 Taurus electric arm chair front seats, PW, PDL, using Power Service additive.
New Truck. 2005 Dodge 2wd dually, 6 speed, gets 15 mpg with 4000 lb camper and pulls any hill easily!
Smart! I've never heard of LH drill bits! Wish I woulda known about 'em before I drilled out broken studs before. The only thing I can offer on this is to reinforce the point made to be VERY CAREFUL about drilling in the exact center of the stud. The only way to do this is to use a center punch and make your start in the center that way. If you don't, the drill will wander and you will end up drilling off-center.
If you don't have anything to do, get a used diesel and a camper!
Truck 1: 1985 F350 dually 4WD 6.9 diesel crew cab auto with 83k original miles. C6 trans, 4.10 rear end. Mods are Banks Turbo, US Gear overdrive, 45gal rear tank, hydroboost brakes, additional leaf springs all around, Hellwig airbags, rear sway bar, GM glowplug controller, fuel Koalescer. 235/85 R16 Michelin XB Rib radials. 11ft.6in Vacationeer cabover camper, TorkLift tiedowns.
Truck 2: 1988 F250 7.3, C6 auto, 2WD w/3.55 limited slip rear axle, Banks Sidewinder Turbo, Gear Vendors overdrive, Utility box, hydraulic lift gate, lumber rack.
Auto: 1987 MBZ 300D Turbo 3.0 Liter 6 cylinder engine. 205K miles. Working on all the "little things" that previous owner neglected. Putting in wvo tank.
The machine shop I work at just cut and drilled out 3 inch and 8 inch steam turbine studs. The large ones cost over $6,000.00 each and are harder than the wife when she says no to anything I want. I take it the head is still on the motor and the motor is still in the truck. Like said just try heat and the pipe wrench is the way I would go but a 3 inch may be a better choice with a cheater if needed. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
I saw the left handed drill bits at autozone.
You can also see the left handed drill bits on the McMaster Carr catalog http://www.mcmaster.com/ at the bottom of the page 2281.
If the broken bolt is in a hole you might try this.
Look at the McMaster-Carr catalog at the bottom of page 2130 you will see a center punch that you can put in a hole and find the center. There is a spring in the housing that centers when you push down in the hole and then center punch the place where you need to drill.
Or i have used a 3/16" drill in the center and started the hole.
It comes in 2 sizes.
You can see this at http://www.mcmaster.com/ on page 2130.
Hope this will help.
Dwight
Hello every one thanks again for the great tips. after I got the manifold off it was pretty easy to drill a hole in what was left of the bolt & used an easy out to remove it. it really made my weekend when it just unscrewed easy. aloha from Hawaii Dean [img]/ubbthreads/images/graemlins/smile.gif[/img]
