Old 04-11-2005, 12:52 PM   #1 (permalink)
external turbo wastegate
Hey guys.
Planning on buying an older ats non-wastergate setup. Mentenioned this to my brother yesterday(he's a member of the ricer crowd) he metioned that they sell external wastegates? any way i could convert/make an old ats nongate to a wastegated turbo???thanks
-Nick [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
1989 F-250: supercab, long bed, 4x4, 5 speed,3.55's up front and rear, turned up pump,Pyro ofcourse!, custom stack, homemade lpg fumigation, more too come...At CSU, the black beauty is for sale...
nickbf2504x4 is offline
Old 04-11-2005, 08:20 PM   #2 (permalink)
Re: external turbo wastegate
c'mon guys...hahah [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 04-11-2005, 08:48 PM   #3 (permalink)
why would you want a wastegate on a turbo made for your truck to be non-wastegate?
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 04-11-2005, 08:50 PM   #4 (permalink)
lww
Some of the Cummins crowd use a small leak off device externally actuated, at times welded to an exhaust housing pre-turbine. On an ATS system, that might be mounted at right angles to the cross over pipe which navigates under the engine driver side back up to passenger feed into tubine housing. Usually on a race truck the exhaust from this device is vented to atmosphere.
You could do this, what would be the point on a non waste-gated ATS turbo though?
1990 F250 with 325oookm - ATS (non wasteGated kit ) on since 0km's / ZF / Single Cab Conversion to 6 seater keeps the family involved / Getting on, but running strong
lww is offline
Old 04-11-2005, 08:51 PM   #5 (permalink)
My Photos: (24)
he mentioned is an older ats so provably they did not come wastegated back then. he want to get it real cheap and add the wastegate option to make it like the new ones i guess.
exekiel
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights
more pics
BOOB Man
soon..
- paint job.
exekiel69 is offline
Old 04-11-2005, 08:53 PM   #6 (permalink)
it doesn't work like that though.
Allen
Old 04-11-2005, 09:43 PM   #7 (permalink)
exekiel
ya
wanted to see if there was a way to make an older non-gated turbo perform like a newer gated one
guess not
thanks [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 04-12-2005, 04:31 AM   #8 (permalink)
My Photos: (33)
In order for that setup to be effective, you will need a smaller turbine housing with an A/R ratio in the .7 to .8 range to speed up the turbo so you can slow it back down with the waste gate to maintain around 10 psi.
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 6.9L IDI, Clark 5sp, 5.57 rinp&pinion, turbo charged and intercooled (with LPG soon).
Huff is offline
