Old 08-01-2006, 12:39 PM   #1 (permalink)
F450 Lift
Has anyone found a lift kit for an 88 F450 or lifted one? I am also looking to see if anyone has converted one to 4X4.
Aaron
88 F-Super Duty Flat Bed Single Cab,Banks turbo kit Factory 5 speed. 4x2
atrice is offline
Old 08-01-2006, 01:43 PM   #2 (permalink)
Re: F450 Lift
I doubt there is a specific kit. How much lift are you looking for?
I believe the F-Superduty had front leaf springs, right?
You could put a couple add-a-leafs front and rear to get a couple inches.
Provided you have front leaf springs, you could use a F350 front axle and transfer case, although you would have to deal with 8 lug front wheels and (maybe) a weaker front axle. I don't believe the 1.5 ton Ford was available in factory 4x4 until the 99 model year, but I could be wrong about that.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 08-01-2006, 02:02 PM   #3 (permalink)
Re: F450 Lift
I am only looking for an inch or or two and it does have front leafs. I don't think that they made these in a 4x4 originally but I was just wondering if it could be done or has been done.
Aaron
atrice is offline
Old 08-01-2006, 04:51 PM   #4 (permalink)
Re: F450 Lift
Anything is possible, but since you already have front leave it makes life a bit easier. Depending on how much cash you want to drop for this, get a front end off of a wreck, newer f-450, then its ten lug. Throw a couple leaves in the works and hammer down like cudder brown.
3 X 06 Ford F250s 6.0 stock 4X4, just got two more, so now 5!
2003 Ford F250 4" Lift, Chipped, 4X4, Diamond Box
2000 Ford F250 7.3 PSD, 4X4, Stock
1999 Ford F350 7.3 PSD, SRW, 4X4, Chipped
1994 Ford F250 7.3 IDIT, 4X4, Pump cranked way up, fuel milage down way low, 6 inch lift on 315/75r16, still rides like a caddy for its day.
And I grow asparagus.
cwatanabe is offline
Old 08-01-2006, 05:12 PM   #5 (permalink)
Re: F450 Lift
An F-450 (99 up) bolt pattern is metric, the F-Superduty bolt pattern is inch dimension. Plus the F-450 uses 19.5" wheels where the F-Superduty uses 16".
That is why I stress the difference between F-Superduty and F-450. They are totally different trucks that happen to have similar load capacities.
Old 08-01-2006, 05:38 PM   #6 (permalink)
Re: F450 Lift
well I learned something new today, but after I read that i went and looked at that f superduty that I have and your totally right about the wheel size, never thought of that. And I would have never guessed that they changed the lug pattern on a 10 lug.
Old 08-01-2006, 07:46 PM   #7 (permalink)
Re: F450 Lift
The pickup truck patterns were changed to metric when the body styles were changed. 97? for the F150 and 99 for the F250 up.
Econoline hasn't been redesigned and is still inch dimension. Although I am not absolutely certain about E450 and above.
Old 08-01-2006, 08:42 PM   #8 (permalink)
Re: F450 Lift
I'd still think just use whatever axle you can find, use 2 different wheels or go aftermarket since you're lifting it. I'm sure there might be hub systems out there that will change your bolt pattern.
Also, maybe switch both of the axles out from a newer F4/550?
2001 F250 Platinum Edition
Hybrids, 38R, Studs, Springs, Forged, etc...
12 second crew cab
Maintain is offline
Old 08-01-2006, 09:58 PM   #9 (permalink)
Re: F450 Lift
There were aftermarket conversions of F-superduty's to 4x4. I've seen a couple driving around and for sale in the TruckTrader. As a matter of fact just within the last month i've seen a '97 f-450 4x4 in the trader. The ones I've seen sat up pretty high with the springs they put on them. Seemed quite top heavy since the ones I saw had buckets on them to do electric line work in sandy areas. Not sure what the front axle was, but it was not a D-60, much bigger.
Interesting because I thought they used a "Super" Dana 60 on the current 4x4 f-550s, whatever a "Super" d-60 is.
Also, the spring spacing is different front and rear between our frames and the newer f550 axles, already checked on that one because I was thinking of upfitting my '89 CC dually to 550 axles the better to tow my 40' 5ver. Not sure about the steering linkage since the spring spacing was off, didn't pay attention to that part. Going back to plan A to get F-Superduty axles and springs to up the GVW.
dontstop is offline
Old 08-01-2006, 10:05 PM   #10 (permalink)
Re: F450 Lift
Oh yeah, as far as a lift, wouldn't any springs from a f-350 4x4 lift work? From what I've seen the leaf spring set up (hangers, location of hangers) on F-supers are the same as the 4x4 f-350, they just used a drop I beam for the 450 and solid drive axle for the 350 4x4. So I would assume that the leafs would fit. You would lose load carrying cap. I would imagine, but if you're lifting it anyway that doesn't sound like a concern for you.
dontstop is offline
Old 08-01-2006, 10:58 PM   #11 (permalink)
Re: F450 Lift
The old F-superdutys used a I beam front axle, with the srpings under the beam.. so putting a 60 under it, would mean putting the axle UNDER the springs, this alone, should give around 4-5" of lift.
Also, I'm pretty sure the 88-97 superduties used 19.5" tires, like like the 99+ 450 and 550.
88' F-350 reg cab, SRW, 4x4.
7.3/ZF5, 4.10's and 33's, rear locker,
banks turbo, 3.5" straight pipe, pump maxed, and advanced 2 degrees.
89' F-150, 351, 435, dual T-cases, rear discs, front electric winch, PTO winch rear, OBA, 40's
Jrod13 is offline
Old 08-01-2006, 11:02 PM   #12 (permalink)
Re: F450 Lift
Well here's a pre-99 that's a 4x4. So I was wrong about the first year. http://p223.ezboard.com/ftow411frm85...icID=148.topic
Old 08-02-2006, 06:57 AM   #13 (permalink)
Re: F450 Lift
Got a '90 and a '88 donor and both have 16" wheels. Gotta wonder why anyone would want to lift these critters. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
'90 F-450 SD, 7.3L IDI DSL, ZF-5 spd manual, 2wd, 11" x 10 spline clutch, 2-wd, contractors 10' dump box, standard cab, bench seat, Dana 80 rear w/4.63:1 gears, 174" wheel base (need lotsa room to turn),weighs in at a little over 9000, no frills.
'96 F-250 PSD standard cab, 2wd, E4OD, 328K on the clock.
daniel45 is offline
Old 08-02-2006, 10:14 AM   #14 (permalink)
Re: F450 Lift
Great thanks for all of your help. I will have to put some thought into converting because I do sometimes tow a 16,000+ LB trailer.
atrice is offline
