Old 08-31-2007, 07:45 AM   #1 (permalink)
Factory IDI turbo??
Guy in the power enhancers for sale forum has one for sale. Is there such a thing?
1992 F 350 crewcab dually 5spd IDI
1964 tube chassis falcon 393 C-4
in the works SBF rear engine dragster
profalcon64 is online now
Old 08-31-2007, 08:23 AM   #2 (permalink)
Mark Kovalsky's Avatar
Re: Factory IDI turbo??
Yes, there was a factory IDI turbo in 1994.
Mark
Mark Kovalsky is offline
Old 08-31-2007, 08:29 AM   #3 (permalink)
I was going to buy a Banks kit, but I guess this would work as well?
Old 08-31-2007, 10:54 AM   #4 (permalink)
The factory IDI turbo was an ATS system. I don't know how the two compare. When I had an IDI I put a Hypermax turbo on it. I liked it!
Mark
Old 08-31-2007, 01:39 PM   #5 (permalink)
Check the motor serial numbers. The turbo blocks numbers started at 1,116,331 and went up from there. Anything lower is a non turbo block. There is plenty of non turbo blocks that can handle a turbo so its best to know what you are buying. Even after you have proven its a turbo block it may or may not be a "turbo motos inside. The turbo motor has a 33mm piston pin size and the non turbo piston pin size is 28mm. They still can handle the turbo but not much boost above 11 lbs.
icanfixall is offline
Old 09-01-2007, 08:08 AM   #6 (permalink)
I'm not going to push 11#s. I just want more towing power. I think 4-5 lbs will do the job.
Old 09-01-2007, 08:44 PM   #7 (permalink)
yes--93 and 94 only--in 94--na 7.3--turbo 7.3--later in year--pwrstrke---only in 5 spd
94_turbo is offline
