Old 05-11-2007, 03:10 PM   #1 (permalink)
Factory Trailer Wiring connectors
Hello all. Well this is my first post here as I'm the proud owner of new-to-me '90 F250 4x4, Extended cab,7.3 IDI. To make a long story short, I'm trying to sort out a mess of trailer wiring.
There are three things that are thwarting my efforts at successfully hooking up a 7-pin connector. I'll start by saying that this truck appears to be factory wired for a trailer but through the years of previous owner mods I'm not sure what was done at the factory and what was done by Joe Mechanic. (One of the previous owners carried a camper and there is bundle of severed wires remaining from that - yay)
I currently get the turn/brake light signals at the back plug but no reverse, power or marker. After studying the Haynes wiring diagram I noticed that there should be a marker light relay. After hunting around (and I mean hunting because I'm partially color blind + the wires are all dirty) I found the 5-pin female connector coming from the harness that should go to a relay. The question is, where is the relay supposed to be? Assuming that this was never there/isn't there, does any one know the part number of the male connector? The female portion has two horizontal blades on the left side, one larger vertical one on the top right, and two smaller pins on the bottom right (combined these last two look like one large vertical with a separator in the middle). Only 4 of the 5 are used: relay power, ground, signal (from light), and switch leg (to trailer marker lights).
The next issue is the brake controller wiring; After researching the posts in this forum I have found the little round gray plug at the bottom of the firewall that is for a brake controller. Two questions: does anyone know of the part number or where I can get the male end? There are three wires in this plug: power, a blue one that runs to the back for the trailer brakes, and a third striped one that I would assume should be the brake signal? This wire is always dead for me. One of the previous owners, for whatever reason , decided that he didn't like the ABS in this truck and had a brake shop bypass the ABS valve. [img]/ubbthreads/images/graemlins/shrug.gif[/img] Could this be why the stripe wire gets no signal? If anyone else could verify on a stock truck that the stripe wire gets power when the brakes are on I would very much appreciate it. I know that I can tap into the light green wire on the crescent shaped connector for this purpose but I would rather keep this install clean.
The last issue is the reverse lights. Is there supposed to be a reverse light wire on the trailer plug for these trucks? If so mine never gets enabled.
2001-F350 Power Stroke,SC,4x4 - Selling to pay off student loans plus there is a new addition to the family [img]/ubbthreads/images/graemlins/smile.gif[/img]
1990 F250,SC,4x4,7.3-IDI (Hopefully adding a Hypermax turbo soon)
Waldo21 is offline
Old 05-11-2007, 04:55 PM   #2 (permalink)
Re: Factory Trailer Wiring connectors
Well I sorted out the issue with regards to the marker light relay. It turns out that it is just a general purpose relay that plugs right onto the end.
One down, two to go.
Waldo21 is offline
Old 05-12-2007, 11:17 AM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Check out....... http://67.18.170.154/home/wiring.asp
Mine is a 93 so we have the engine compartment fuse box which handles the trailer.
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 05-13-2007, 11:38 AM   #4 (permalink)
Willie's Avatar
check your PM box
Bob
My Pictures
1984 Bronco II 4x4 day to day driver : Winter
2005 Explorer Sportrac 4x4 day to day driver : Summer
1991 F350 / Crew cab , Engine 7.3,E4OD tranny. No Turbo but has propane and pyro gauge. The truck is American, complete with a Miles per Hour speedo. Digital trans. temp gauge and voltmeter. Front Captain seats. Control switches for DRL's , Fog lites, High speed idle, Engine kill and scene lites. On board " York " compressed air, Air horns and built in hose reel behind the rear seat. Power bar distribution box from a 1999 Ford Explorer . Checker plate running boards and Frieghtliner mud flaps. LED turn signals in the factory mirrors. DC to AC inverter to run the coffee maker <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> Soon to be updated with more toys as time & $$$ permit. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Willie is offline
