Fan Clutch Removal - Diesel Forum - TheDieselStop.com
Old 11-17-2006, 05:25 PM   #1 (permalink)
Fan Clutch Removal
Purchased new water pump pulley to help alleviate the belt wobble. Only problem: how do I get the fan off?? Short of purchasing the Ford/navistar special removal tools for one time use.
'90 F250 4x4 std cab 5 sp. 7.3 IDI
Velvet spring shackles, K&N Air, Warn Hubs
Baldwin 5200 coolant filter, 175K & counting
Captj is offline   Reply With Quote
Old 11-17-2006, 05:58 PM   #2 (permalink)
GenLightening's Avatar
Re: Fan Clutch Removal
Someone said that Napa rents them. I have not checked yet, but I'll need to soon.
Doug
1988 Chevy CC DRW w/a 7.3L IDI w/Banks Turbo
E4OD w/Baumann Transcommand
Racer-X triple disc TC
US Gear Exhaust Brake
4.10 Chevy Diff
GenLightening is offline   Reply With Quote
Old 11-17-2006, 06:00 PM   #3 (permalink)
Some auto parts stores have free rental on the tool, And some people have gotten it off by hitting the nut with a chisel and hammer. Never tried that myself.
1994 F250 7.3 IDI Factory turbo 5 speed Banks kit
9ENGEL is offline   Reply With Quote
Old 11-17-2006, 06:08 PM   #4 (permalink)
Hammer and chisel will really bugger up the nut.
I was lucky enough to have a regular open end wrench the right size and "shocked" it loose by hitting the wrench with a hammer. Personally I would recommend buying the right tools to do the job.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline   Reply With Quote
Old 11-17-2006, 06:19 PM   #5 (permalink)
The fan nut is 1 7/8 ". It is reverse thread. A chain wrench on the pully works fine. Be carefully not to hit the radiator as youy remove the fan and clutch.
89 Ford F250 XLT 7.3 4X4 5 Speed 224000 miles
DMAN is offline   Reply With Quote
Old 11-17-2006, 07:05 PM   #6 (permalink)
Yeah, it is Lefthand threads, instead of righthand threads.
I made a wrench outa 2 1/2 x 1/4 flatbar & torch one time. Got thru & rattlecanned it silver, painted SnapOn on it, hung it on the shop wall. Stayed there about 4 years. Needed a piece of flatbar about that size oneday, cut it up & used it. Very next week I needed my "SnapOn" wrench.....
[img]/ubbthreads/images/graemlins/mad.gif[/img] [img]/ubbthreads/images/graemlins/mad.gif[/img]
'90F350 CC DRW 2WD 7.3 ATS nongate,'99 PS IC mounted but not hooked up yet, Ram air, RDT, ZF5, US Gear Ex-Brake, 4" body lift, 2 1/2" suspension lift, Holly Red, add-on Mazda (82-85) NAPA Gold 6 micron fuel filter #3395, Cat watertrap/screen filter, 2 ea. 10 micron Goldenrod filters, 2 fuel/coolant heat exchangers, heated fuel lines, filters, & 1 F/tank, DCA4 spin-on coolant filter, windshield washer & rad. overflow tanks & vac. can mted. below & underneath for more room!!
ttman4 is offline   Reply With Quote
Old 11-17-2006, 07:57 PM   #7 (permalink)
Dave Haven's Avatar
My Photos: (16)
Hammer and chisel will really bugger up the nut...
[/ QUOTE ]It doesn't do the water pump bearings any good, either [img]/ubbthreads/images/graemlins/tongue.gif[/img]
Dave Haven is offline   Reply With Quote
Old 11-17-2006, 08:25 PM   #8 (permalink)
I recently changed my fan clutch and had considerable trouble finding the right two tool set. The tools are hard to do without. My local AutoZone only had the smaller size for loan which will not work on the 7.3L. I was able to find the right size at a local store called Winchester Auto, but they are probably local to the San Jose, CA, area. They charged $7/day rent, not free but better than over $100 to purchase. If you call around, you might find some place that rents them. Just make sure they have the right set because the set for a smaller engine is more common and won't work for us. Good luck.
1989 F-250 XLT Lariat 7.3 diesel non-turbo, lifted 4x4, supercab, 4.10 LS, C6 Auto, 220k miles.
MikeInCA is offline   Reply With Quote
Old 11-17-2006, 10:39 PM   #9 (permalink)
cdnsarguy's Avatar
My Photos: (109)
The tools your looking for measure.........
Clutch Fan wrench opening sizes.
Pulley.... 3 1/4" wide by 4" deep
Fan nut.... 1 7/8" wide by 2 1/4" deep
Torque specs 83-113 Ftlbs
Remember left hand thread for the nut.
http://www.otctools.com/products/detail.php?id=1525
Seen the same tool kit at www.princesauto.com for $35 CDN
Proud Canadian BOOB man too!!
cdnsarguy is offline   Reply With Quote
Old 11-18-2006, 11:13 AM   #10 (permalink)
I didn't intend to recommend an inferior method of removal, just passing on information I've read here. In thinking back, however, I think people that used that method were doing it to replace the water pump, so bearings would not be an issue. But it still has to be reinstalled.
In this situation, since he is only replacing the pulley, the proper tool should be used.
I agree about using the right tool, which is why I bought one when my water pump went south. And was glad I did when that water pump started leaking a few months later.
Old 11-18-2006, 10:47 PM   #11 (permalink)
My Photos: (17)
Check the "Links" n my Signature to fix that alt belt. It's real easy. [img]/ubbthreads/images/graemlins/shrug.gif[/img]OkeGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline   Reply With Quote
Old 11-20-2006, 10:14 AM   #12 (permalink)
Guys, thanks for the helpful replies.
Okiegringo- installed your idler pulley but belt continues to wobble hence the water pulley removal question.
Old 07-19-2012, 06:35 PM   #13 (permalink)
I have the tools for this as loaner tools from Oreilly since my fan clutch went bad. Excuse my ignorance but where does the pulley wrench go on?
Chris90F250Diesel4x4 is offline   Reply With Quote
