Flex plate needed or info to make one even - Diesel Forum - TheDieselStop.com
Old 05-28-2009, 10:51 AM   #1 (permalink)
Send a message via MSN to Whiskey Kennels Send a message via Yahoo to Whiskey Kennels
Unhappy Flex plate needed or info to make one even
We are having a terrible time trying to find a flex plate for our 1994 7.3 Turbo diesel. We have been looking for a couple months now. We have been told by Ford that the flex plate for our truck was only used for 6 months. The part is now obsolete by Ford and no after markets are being made either. We have not been able to find a replacement and ours is all but worthless. the teeth are all bad on ours. Does anyone have a flex plate from a 1994 Turbo 7.3 IDI that they are willing to sell???? or know of one??
We are at the point of having one made however this is also a dead end since Ford will not tell us the information we need..such as thickness of plate, number of teeth, spacing of bolt patern etc.. Does anyone have this information so that we can have one made??? We cannot take ours out as once it is out it cannot be put back in.. and this truck is my only way to work which includes travel all over the US..kind of far to walk lol..
Any help would be appreciated greatly!!
Whiskey Kennels is offline
Old 05-29-2009, 11:47 PM   #2 (permalink)
Bill1013's Avatar
I have a 92 7.3 IDI that has a just flex plate on it with a spacer about an inch thick. Don't know wether that was the original since I bought it used. If your's has the spacer, why can't you just use a regular fly wheel and do away with the spacer. There are nine bolt holes and one is used for a dowel pin. Don't have the bolt circle dimension. I will measure up the crank bolt hole circle and post it tomorrow evening sometime.
Edit: Looked on the other forum for a flex plate for you, disregard my suggestion on the fly wheel, was thinking wrong. You do need a flex plate.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
Old 05-30-2009, 12:01 AM   #3 (permalink)
My Photos: (10)
They're out there. I rebuilt my engine 3 yrs ago and my machinist found my original with a crack in it. He was able to get a new one for me. I'll see if I can get ahold of him to see where he got mine from.
92 F350 XLT Crewcab dually, 225K miles ATS turbo, 4 inch exhaust, fresh IP & new matched BB injectors, Holly Red pump, K&N, E40D, 2 aux coolers, A-pillar guages, 410 limited-slip rear, Rancho 9000s, towing package, full running boards, mud flaps, 94' Ford (Alcoa) aluminum wheels, Predator camper shell, 600 watts of Sony/Boston Acoustics! Complete engine rebuild at 176k miles. Ford reman E4OD at 204k miles.
2001 Komfort 26FS
My Truck
Fozz is offline
