Front End Help/1992 f250 4x2
The front end does not pull or do a death shake.It rattles and shakes a little going over slower roads and bumps...On the highway it is fine.Any suggestions would be greatly appreciated, Thanks, Rob
1992 F-250 7.3 IDI 2wd Auto 156000 miles
Blended user w/rear tank/Front tank reg-diesel.
DSE Blend in rear tank.
20 gal WVO/2 gal kero/1 gal gas/15 oz. Diesel kleen/3.5 oz. DSE Used Blend from 144,000 miles. Sold , but a friend has it,so I will keep it in signature.
1988 F-250 7.3 IDI 4wd non turbo c6 auto crew cab. w/ 136500
Blended DSE fuel in rear tank.Started 2-25-08 @ 132000 miles.Changed O-rings,rubber fuel lines,cleaned injectors,changed fuel and air filter.Changed Wiper motor 4-4-08.Cleaned injectors again 10-1-08 136000 miles.11-4-08-Changed all fuel line clamps and glow plugs(Wellman)
1991 F-250 7.3 IDI 2wd non-turbo,E4OD,181,000 miles.Started DSE blend in front tank 11-14-08.Changed air filter, injector to injector line fuel hoses from 5/16 to 1/4".Was a truck of a fleet manager of an oil company.Has a tommygate lift.All service records from 1991!
