front sag - Diesel Forum - TheDieselStop.com
Old 03-07-2005, 04:24 AM   #1 (permalink)
front sag
been browsing the archives the last couple of days and have been taking notes and bookmarking useful info, but every front sag post i've seen pertains to the 4wd front leaf, i have a 2wd with the open coil. What would be an economical way to remedy the sag? Doing front brakes tomorrow, and will give #s to level front end. Rough guess would be about 2-3 inches.
Ryan
91 f-350, dually, 7.3 diesel. 2wd, 4.10 gears LS. E4OD. New injectors, lift pump, and fuel filter at current 85,000 miles. Autometer pyro and fuel turned up. 3" exhaust with walker "btm" muffler
http://community.webshots.com/user/olivera_149
olivera149 is offline
Old 03-07-2005, 05:59 PM   #2 (permalink)
My Photos: (10)
Re: front sag
Hey Ryan,
Thanks for the info on AK in your previous PM.
Regarding your front end sag. Look on ebay or an internet search for a product made by Daystar that lifts the front end an inch or two. There are two ways to install. One is to loosen the pressure on the coil spring and install the spacer bewteen the coil/mounting area. The other method is to actually thread the spacer into the coils. They are reasonably priced. I bought a set for my '91 GMC 2500 but never got around to install them before I sold it.
Lance
'89 F350 Crew Cab, SRW, 7.3 with Hypermax turbo, 5 sp, 3.55 rear, 265/75/16's, 2" body lift, Bilsteins, LUK clutch, 142,000 miles, 2nd owner
la350 is offline
Old 03-07-2005, 08:10 PM   #3 (permalink)
Re: front sag
There's a company called Autospeciality. They are primarily into alignment repair parts and they have coil spring spacers that are full round, made out of aluminum. I raised the front end of my Cherokee with a set. The price was pretty good and they were a quality product. Check with some of the speciality front end shops in the area. Their websight is http://www.autospecialty.com/
1993 F-250 XLT 4X4 7.3 nat asp. Banks turbo installed 02/13/05, straight piped, 5 speed, 4.10 gears 235/85R16 stock wheels
1990 F-150 4X4 302 5 speed
1976 CJ7 4X4 258 3 speed
1995 Grand Cherokee 4x4 4.0 litre
1990 K-2500 GMC 4X4 350 Auto
1979 F-150 4x2 300/6 4speed 4bbl dual headers/exhaust
1986 Vacationeer 23' Fifth Wheel
2005 Gooseneck(brand) 4 horse gooseneck stock trailer
1941 Allis Chalmers C Ser# C541
1948 Allis Chalmers C wide front
ARIZHNT is offline
Old 03-08-2005, 03:39 AM   #4 (permalink)
Re: front sag
Finished the brakes and the front needs to be raised 3.25 inches to be level. Would new springs be the way to go with this much fatigue or the spring spacers that you mentioned. If spacers any recomendations on poly or the aluminum.
Old 03-08-2005, 04:28 AM   #5 (permalink)
PSDfreak's Avatar
Re: front sag
I would look into new springs...a spacer would do the trick, but performance wise, it seems to me that a set of springs would be optimal solution...
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
Old 03-08-2005, 04:58 AM   #6 (permalink)
Re: front sag
any recomendations on coil spring brands? Would rather replace with high quality springs that wont fatigue quickly.
