Does anyone have any experience using transmission fluid as a fuel additive? I have heard stories, but not from 1st hand. Some say good for lubrication, others don't know. Is the PS additive sufficient for this new low sulfur fuel now sold? Any input will be greatly appreciated. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
89 F250, 7.3 IDI n/a, overhauled E4OD with upgrades & billet torque converter 12/05, 3.55, all sensors replaced, 15k High volume low resistance tranny cooler. Alternator mod. Headlight mod.
I'd like to hear input on this also!
What about a quart of oil every tank?
I know there are additives (PS,DK) at Walmart and truck stops
but one is not always at Walmart or a truck stop.
At the cost of fuel a quart of new oil isn't bad at maybe
one quart per tank.
90 F350 flatbed dually 7.3 IDI E4OD(self rebuild)
I think there was a discussion on using atf as a fuel additive recently, maybe on the "General Diesel" thread, but not sure.
The new labeling regs require that any product designed as a fuel additive must state on the label whether they meet the specs for the new ulsd fuel. No doubt there is old inventory on store and truckstop shelves that was produced before the new regs, so I'm sure there's not 100% compliance. Check the label on the PS bottle to be sure.
And since atf isn't designed to be a fuel additive, it doesn't require any such labeling.
I can't see how it would hurt lubricity, but since the cetane number on atf is so much lower than diesel, using too much of it could make your engine run sluggish.
I have, I first heard about it from an old diesel mechanic and did not put stock into it thinking it was an old wise-tail but then I read about how good it is in an article in Diesel Power Magazine. The nice thing about it is that the cheapest automatic transmission fluid on the shelf is good enough and can cost less than diesel fuel additives.
1991 F-250 HD, Lariat XLT, 1 ton, extended cab, 125,000 miles, 7.3 non-turbo V8 diesel, E40D auto trans, 2 wheel drive, air, power everything and it works!
I've been pre-filling my fuel filter with atf for years during replacement. I have never had a problem. I've heard that it will leave deposits on the injectors and affect the fuel flow but I have never had a miss or a decrease in fuel mileage.
Thanks for all the replies. I will be putting some in my tanks today when I fill up. I'll let you know later if I can find out any more information on this.
i have used atf in the past but remember it will turn your fuel red & the feds if they dip you might claim that your running untaxed off-road fuel. so for me nowdays in the filter only.
97 dodge 2500 4x4 cc lb 12V auto 3.54 pillar gauges 215 nozzels
31'TT at 8000 lbs
94 explorer
Using ATF in the diesel fuel has been done for about 50 years now. The ATF will add more lubricating to the IP and injectors. In the older diesels ATF works just fine. A word of caution, do not use ATF in 6.0 engines. ATF being pressurized to the pressures of the 6.0 fuel system could caused damage.
Thanks,
J.R.
The Fleet:
'86 F-250 2wd w/ 89 7.3 non turbo, T-19, dual tanks, maintenance body, GP push button mod. "The Diesel" - Nevermind the mule just load the cart.
'86 F-250 2wd w/ 6.9L non turbo, C6, dual tanks See "Old Blue" here My First Blackstone!'97 F350 4 door dually auto '05 John Deere Gator 4X4 HP Gas, dump bed, winch.
Gets the bills paid: http://www.youth-hall.com
Is it just any kind of ATF? There's DextronII, the Ford ATF and the Chrysler ATF. Also for lubriccation of the injector pump would you need it for every tank full??? also how much is too much and how little is too little????
I still use Pwr Svc. But currently using Howe's since I got two gallons free....... [img]/ubbthreads/images/graemlins/smokin.gif[/img]
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
It MAY be ok for you guys living in the warmer climates however dont forget tranny fluid dosent have any anti-gel properties in it.Personally i wouldnt use it,after replacing my pump 3 years ago at a cost of over $900cdn(pump price only) i will contuniue to use a proper fuel additive that i know has all the properties needed for pump longetivity.BTW i use it EVERY time i fuel up.
1992 f-350.4x4 srw.rebuilt e4od.rebuilt injection pump. no soup bowl,no muffler,straight pipe.. 8 foot power angle Artic blade/7 1/2 ft p/a Fisher blade. 280,000kms and counting.Paint to come.
