Old 12-21-2005, 12:22 AM   #1 (permalink)
fuel filter
are there any tips on changing the fuel filter? dont i just remove the old one fill the new and replace it?
93 f350 5 speed cc long bed 4x4 162,000 mi 4 inch lift 35" tires.
76 early bronco in resto.
southern oregon on the coast brookings
cams76 is offline
Old 12-21-2005, 01:22 AM   #2 (permalink)
My Photos: (23)
Re: fuel filter
i think that pretty much sums it up. i'd fill the filter w/ Howes or Stanadyne or PS, myself...
some purge the air via the schraeder valve afterwards, but you can also just let it purge by cranking if you think your batts & starter are up to it. you can kill your starter with 30 sec+ cranks. good batts are essential to starting these old girls (especially in cold weather),so don't kill them while you're at it.
do you know how to jump your starter while under the hood?
Frank
Unofficial BOOB man (unofficial BUTT division: brotherhood of un-turboed trucks)
meet Big Black, my 1992 International 3/4 ton pickup wrapped in a Ford skin: 2wd, LWB, N/A 7.3, ZF5, 3.55s. 249k miles.
Amsoil bypass & AF. 3" true duals. no soup for me. 'ghetto' fresh air. Baja block drains. bottle broke. slobber tube. true dual 3" straight pipes. now a TRUE oil burner - she's drinking 15% Bunker Fuel (WMO).
soulpatchfr is offline
Old 12-21-2005, 01:57 AM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: fuel filter
Best to drain some fuel off before removing, use the drain wheel on the bottom. Drain fuel into a small container under the drain line. Disconnect the electrical connector for the water in fuel sender and drain line. Now unscrew the complete filter with the base attached, filter wrench may be needed. Drain the rest of the filter, remove the base from the filter.
Clean then screw the base on the new filter using new Oring (lubricated) hand tight. Fill new filter 3/4 with new diesel fuel or approved fuel additive, lubricate filter seal and screw on to filter header. I use a filter wrench for 1/2-1 extra turn. Attach WIF sender wire and drain line, now your done. Any leaks tighten as required.
If you use fuel to refill the filter always use the outer small holes, that is the unfiltered fuel area. Never drain old fuel from the old filter into the new one.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 12-21-2005, 04:01 AM   #4 (permalink)
Re: fuel filter
When I changed mine, I couldn't get it to start. So I pulled it off again and filled it with ATF. Reinstalled and she fired right off. Chased all the mosquitoes out of the neighborhood too. [img]/ubbthreads/images/graemlins/grin.gif[/img]
'91 F-350 Lariet Dually Deezal, supercab, 2wd, N/A 7.3 idi, ZF 5 spd
No soup bowl
220,000+ and counting.
OG block drains, Idler pulley mod
Luk SM clutch conversion
'93 CR250R, FMF, Race Tech, not crash proof
Bullitt350 is offline
Old 12-21-2005, 05:45 AM   #5 (permalink)
Re: fuel filter
I've had good luck cleaning the bowl,threads, and all valves with brake cleaner or gumout and then pouring just a little motor oil in the bowl and then spreading a film of oil over the bowl interior, threads, and both O-rings. I fill the filter with fuel and reinstall.
Changing a fuel filter often times disturbs a tight seal and causes air to get into the fuel system. Taking a few minutes to cover all the bases has been time well spent for me.
'93 F-250, - most original at 252K miles, rebuilt E4OD 220K miles
Greenie is offline
Old 12-21-2005, 02:05 PM   #6 (permalink)
Re: fuel filter
your talking to someone who has never done this before whats a bowl what threads what valves? please go into more detail i have an idea but want to be sure.
cams76 is offline
Old 12-21-2005, 02:16 PM   #7 (permalink)
Re: fuel filter
Have faith, just like an oil filter kinda, just take it off and all will become clear to you. Just unhook the wire on the bottom, and unscrew the filter....
Kennyray
1990 F250 4x4,3.55, E4OD, LWB,Supercab, 7.3 XLT Lariat HD. Alum steps, Red/Tan, Red interior, Captains Chairs, Sirius Satellite Radio. 16X8 Alum Wheels. Alum. Tool Boxes all the way around. 215,000 Miles and climbing.
BOOB man in Alabama. WVO experimintation in progress.
kennyrayonline is offline
Old 12-22-2005, 03:10 AM   #8 (permalink)
Re: fuel filter
the valve is up on top of the filter housing and looks like a tire stem (Schrader valve). the bowl is the bottom piece of the filter. If you unscrew the largest part (the filter) it will have a bottom piece that you will need to unscrew also. if you look at the new filter it should become apperent where you need to put evertything.
Tyler
89 F-250HD 7.3L XLT Lariat 4x4, 5spd, 4.10 rear - ~200,000 miles
Best mpg - 17.5 (drafting behind a semi doing 65)
My Truck Pics
fsSnowboard is offline
Old 12-22-2005, 07:16 AM   #9 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: fuel filter
Visit ...... web page good info and lots of pictures... [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
