Fuel Filter Light - Diesel Forum - TheDieselStop.com
Old 11-04-2009, 06:41 PM   #1 (permalink)
93 f 350's Avatar
Fuel Filter Light
Hello all ,i was hauling somewhat heavy the other day ,and the fuel filter light
on my truck stayed on whenever i stayed on the pedal ,when i released the pedal it go off ,what does that indicate also how do i check the heater on the filter (fuses wiring etc )and can i cap the return valve on the filter that goes to #1 inj.to increase pres.,i have an electric inline pump and runs at
3 to 4 psi idling
thanks for any info
93 f350 7.3 non turbo ,super duty ,man.trans,dump box 4x4 dually,electric lift pump ,elect.clutch driven hydraulic pump
93 f 350 is offline
Old 11-04-2009, 06:49 PM   #2 (permalink)
chuckster57's Avatar
The "fuel filter" light is activated by pressure and it normaly indicates a plugged or clogged filter. Mine did it about a week after I bought the truck and filled both tanks. Took a 200 mile trip and it came on about 1/2 way home. I took the filter off and found a bunch of junk in it. Changed it and it hasn't cme back on since.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 11-04-2009, 07:53 PM   #3 (permalink)
The fuel heater is too small and poorly placed to be of any use. It's very expensive too. As long as it's not leaking I'd leave it alone.
'93 F-250, - most original at 252K miles, rebuilt E4OD 220K miles
Greenie is offline
Old 11-04-2009, 08:57 PM   #4 (permalink)
rsr911's Avatar
I run blends in my van and when I was first experimenting I had to change a lot of filters before I got my pre-filtering down cold. The light is coming on either because the filter is partially clogged or your electric pump is dying a slow death. What kind of pump is it? I'd replace the filter for good measure anyway though.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
rsr911 is offline
