Old 01-01-2008, 12:48 AM   #1 (permalink)
kd8bao's Avatar
Send a message via AIM to kd8bao Send a message via Yahoo to kd8bao
Fuel Filter / Water Seperator conversion
I did a search for this and didnt find anything. I have a 93 F-350 IDI non-turbo. I want to change the the existing fuel filter from the flow thru with the bottom cap to a one piece filter. wondering if anyone has done this and has any info. Thanks in advance.
Henry
HillBilly-Limo
1993 Grease Fired F-350 4x4 Crew Cab Long Bed
Just Turned 100K 8-1-08
http://www.AMMOMotorsports.com
kd8bao is offline
Old 01-01-2008, 01:01 AM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Fuel Filter / Water Seperator conversion
Wix and others have the ones with the drain spigot on the bottom of the filter...... WIX 33617 or a Baldwin BF 1222-SP they have one that you can put the WIF sender in too and still use it.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 01-01-2008, 05:42 AM   #3 (permalink)
Squid63's Avatar
Send a message via AIM to Squid63
WIX 33617 (NAPA 3617) is a 1-piece filter with a drain and sensor port. I switched mine over and it's great, no more leaks.
94 F250 Supercab 4x4, 7.3 IDI Turbo, NV4500 5 speed, 4.10s
95 F350 Crew Cab 4x2, 7.3 DI, ZF 5 speed, 3.55s
Squid63 is offline
Old 01-01-2008, 06:16 AM   #4 (permalink)
Henry, The 33617 is what I use. Make sure you have the sensor that screws into the bottom of the filter from the old one.When you go to put the sensor on the new filter , be sure to pull the plastic/rubber like plug out of the new filter 1st. Keep a mental note to do this everytime you change.I changed mine last month and I was puzzled at how there were no threads to put the sensor on till I remembered to take the plug out...duh.
CDNsarguy is the best helper out there, Rob
1992 F-250 7.3 IDI 2wd Auto 156000 miles
Blended user w/rear tank/Front tank reg-diesel.
DSE Blend in rear tank.
20 gal WVO/2 gal kero/1 gal gas/15 oz. Diesel kleen/3.5 oz. DSE Used Blend from 144,000 miles. Sold , but a friend has it,so I will keep it in signature.
1988 F-250 7.3 IDI 4wd non turbo c6 auto crew cab. w/ 136500
Blended DSE fuel in rear tank.Started 2-25-08 @ 132000 miles.Changed O-rings,rubber fuel lines,cleaned injectors,changed fuel and air filter.Changed Wiper motor 4-4-08.Cleaned injectors again 10-1-08 136000 miles.11-4-08-Changed all fuel line clamps and glow plugs(Wellman)
1991 F-250 7.3 IDI 2wd non-turbo,E4OD,181,000 miles.Started DSE blend in front tank 11-14-08.Changed air filter, injector to injector line fuel hoses from 5/16 to 1/4".Was a truck of a fleet manager of an oil company.Has a tommygate lift.All service records from 1991!
Sushibob64 is offline
Old 08-25-2008, 09:41 PM   #5 (permalink)
kd8bao's Avatar
thanks
HillBilly-Limo
kd8bao is offline
