ok so i started my truck this morning and the fuel gauge was spiked above full. the it came back down to just below full as if it were working properly. i let the truck run for 5 min and when i took off forward pulling down the driveway the gauge spiked passed full and was bounceing crazy from 3/4 to over full. then settled down, it has never done this before. i have 75 miles on this tank so i should be below 3/4, but i did top it off pretty good last fill up. dont get me wrong it moves when i gas it and stop but usualy when around 1/2 tank. from the other posts i have read most guys are either full or empty. just curious of your thoughts, thanks in advance
HillBilly-Limo
1993 Grease Fired F-350 4x4 Crew Cab Long Bed
Just Turned 100K 8-1-08 http://www.AMMOMotorsports.com
Could be the sender is wearing out....... You can check for the ohms.......
93 info
Here are the fuel guage test #s
22 ohms sent to the guage it reads empty "E"
145 ohm sent to the guage it reads full "F"
Here are the sender test #s
Sender at empty stop 14-18 ohms
Sender at full stop 154-162 ohms
I am experiencing a similar problem so please continue to post replies here.
My guage was functioning properly and then suddenly started the dance mentioned. I should have a quarter tank of fuel in the rear tank and a full tank up front. When I switch to the front tank the guage shows less than a quarter. When I switch to the rear tank the guage dances above full and 3/4 full.
2005 F-350 XLT 4x4 SRW Reg Cab long bed 6.0PS tow command
1986 F-250 4x4 woods truck - well broke in 460 gas, they can hear the sucking sound all the way to Texas!
1989 F-250 XLT 4x4 SRW 7.3 IDI soon to replace the '86
i went to the tank and checked to ohms or at least tried to. i poked the wires with the meter and i got 800+/- one way and the meter shut off the other way. as in i couldnt tell what was positive or neg so i just poked. so i am assuming the unit is bad. the rear unit still sends a good signal to the gauge but i also am assuming the switch doesnt work because the truck will die afetr a minute or running on the rear. when i flip the switch the valve makes noise like it is switching. any thoughts
HillBilly-Limo
Could be if the tank plastic pickup is broken off...... truck will run out of fuel at 1/4 tank level. This is a known problem on the diesel tanks........
With the wires disconnected from the tank sender...... check ohm readings of tank sender(s) to check guage send correct ohms to guage via the wires.
here's something i actually know something about: there's no pos or neg with ohms (resistance). so it will measure the same both ways
if you are testing the gauge and want to send ohms you can use a potentiometer, get a 1k linear taper potentiometer from Radioshack or electronics store. Use the ohm meter to set your pot to the "full" value (145ohms) using the center lug and either outer lug of the pot. Then connect the pot to the gauge. Repeat for the 'empty' value.
My first project truck: '90 F250 7.3L IDI 2WD, camper shell, primed and ready to pick color(s). Dual exhaust WORK DONE: replaced starter, new return lines/injector-caps, new glow plugs/wiring harness/controller-relay, wiring fixes, replaced brake cylinders/pads, two-tank SVO conversion
