Fuel Guage - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 11-10-2012, 01:35 PM Thread Starter
Fuel Guage
It's been awhile since I have had a problem but my fuel guage on my forward tank has stopped working. Two years ago, I replaced this tank and it has always been ok. Thinking that maybe I had a grounding problem, today I cleaned the tank ground with no success in getting the guage to work. I also checked the fuses.
When I replaced the tank, I was advised to just cut the fuel lines and use the shark type connector to reconnect rather than mess around with the o-rings and such. Obviously it looks like I have to go through this again, drop the tank and check the float. Can I just cut the lines again or should I attempt to disconnect at the switch? So much easier to cut the lines but reconnecting could be a problem.
If I leave the fuel switch off, can I still drive it without sucking air or losing fuel? It's getting colder and I want to do this job at my discretion.
1994 F250 HD, IDI Diesel, 3:55 gears, K&N filter, Hayden Tranny Cooler, Monroe HD SensaTrac shocks, dual pillar pod with temp & tranny guage, poly fuel tanks
caseyj is offline
post #2 of 5 (permalink) Old 11-12-2012, 12:27 PM Thread Starter
Didn't mean to throw a problem at you that was be outside your expetise. I will let you know the outcome after I dig into this. Whatever happened to Pete?
caseyj is offline
post #3 of 5 (permalink) Old 11-12-2012, 04:58 PM
drinkypoo's Avatar
My Photos: (25)
I didn't have any trouble disconnecting and reconnecting my fuel lines. I used new plastic clips, you can usually get them in the HELP section. I didn't do anything with the O-Rings, which were fine. I may have polished some rust off of one of the projecting hard lines.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #4 of 5 (permalink) Old 11-12-2012, 09:45 PM Thread Starter
Thank you, I've looked at that area yesterday and it looks doable. I'm not too excited about laying on my back under the truck to drop the tank even though I've done it before. I have also considered pulling the bed off as I also want to install a Banks down pipe (3") that I purchased some time back. I'm toying with the idea of a flat bed. Again, thank you for your response.
caseyj is offline
post #5 of 5 (permalink) Old 11-13-2012, 07:19 AM
drinkypoo's Avatar
My Photos: (25)
You should pull the bed and service both tanks while you're there, especially if you haven't already had to replace your pickup feet. Propping up the bed (I stuck some 1" channel into the channel that's welded to the bottom of the bed) is easier than dropping the tank, at least if your carriage bolts aren't frozen.
