Fuel Injector Cleaner 92 7.3L diesel f350 - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 07-06-2006, 10:59 PM Thread Starter
hi i have a f350 7.3 diesel motor 1992
i want to know what i should use to clean the fuel lines injectors
is there an additive to the fuel people should recommend
my stupid engine wont let me rev up to 2 1/2 to 3rpm without gettin whitish blue smoke and then sputtering to stall
i can idle this thing all day and its fine. i was running some dirty biodiesel fuel through it before i had this problem. i put a brand new fuel filter on today
brattzzzzz is offline
post #2 of 12 (permalink) Old 07-07-2006, 03:01 PM
cdnsarguy's Avatar
My Photos: (109)
Re: Fuel Injector Cleaner 92 7.3L diesel f350
Powerservice or Stanadyne lubricity/cleaning conditioners are what we use. Sounds like your governor is shutting down the engine or the advance is sticking........... One other thing may be a bad air leak at high RPM. Check your fuel lift pump pressure at the filter schrader valve.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 12 (permalink) Old 07-07-2006, 03:03 PM Thread Starter
what should my fuel pressure be at the filter schrader valve.
i just changed my fuel filter and i held down the needle on the filter schrader valve to see what happens and some air came out and then the motor started sputtering and died!
post #4 of 12 (permalink) Old 07-08-2006, 05:02 AM Thread Starter
has anyone tryed SEA FOAM?
post #5 of 12 (permalink) Old 07-08-2006, 08:28 PM
I always carry a coupla cans of Sea Foam so that if I have to change my filter I just use the SF to refill the new filter and It will start up instantly. I am using WVO so I need to carry extra filters.
1990 7.3, 1993 7.3 with ATS turbo. Use these for hauling Lead. !983 300cd used for 28mpg
jenbob is offline
post #6 of 12 (permalink) Old 07-08-2006, 08:33 PM Thread Starter
where is SEA FOAM sold at
i tryed some stuff today called DIESEL KLEEN by power service from autozone
and it didnt do anything at all
http://www.powerservice.com/dieselkleen_cetane.asp
post #7 of 12 (permalink) Old 07-08-2006, 08:37 PM Thread Starter
yeah and i siphoned my fuel lines they are very clean and flow nicely so i know i dont got junk in there
maybe my fuel pump is going bad
how do i test a fuel injection pump to see if its good or not
post #8 of 12 (permalink) Old 07-08-2006, 08:45 PM Thread Starter
what is a governer and why would that be the problem
what do i do just replace it to test if its bad
post #9 of 12 (permalink) Old 07-09-2006, 11:19 AM
Sounds like as stated above. What you need to do is double dose the amount of injector cleaner in the fuel. It wont hurt anything. The pressure the lift upmp puts out will be 5 to 7 lbs at the shrader valve. If your oil level is creating up the lift pump may have a hole in the diaphram and leaking diesel into the oil pan. How many miles are on the injectors and injection upmp? They don't usually last much more than about 100,000 to 150,000 miles at best. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
icanfixall is offline
post #10 of 12 (permalink) Old 07-09-2006, 12:22 PM Thread Starter
i believe the injectors are a year old and they are bosche ones
and the fuel pump probaby has 200,000 miles on it
post #11 of 12 (permalink) Old 07-12-2006, 11:42 AM
Depending on how corroded your injectors are, you may have to go through a couple of tanks of fuel before you notice a difference in performance.
I've had the same experience with diesel kleen as you did.
CharlyJoe is offline
post #12 of 12 (permalink) Old 07-12-2006, 11:45 PM Thread Starter
well i believe my problem is my fuel pressure regulator
its on the line before the fuel filter
i blew it out and the truck ran fine for a couple days
but today it started running out of gas again on the hill i climb to my house
so i think it maybe cloged again or going bad or i dont know
