Fuel leak in my 1993 F250 7.3 idi non-turbo - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 05-07-2008, 02:02 PM Thread Starter
Looking for some ideas on what may be leaking fuel in my 1993 F250 7.3 idi. I see fuel oil dripping on ground after driving and smell diesel in garage. Mechanics initial suggestion is to replace injection pump. However truck runs and drives strong, Appears to be leaking fuel from top of engine. Bottom of injector pump is wet and top of engine block has fuel on it. I would like a some ideas of other leak areas on this motor before I let the mechanic order a new injection pump, which it may or may not need. It is the original pump.
Thanks for the help!
1993 F-250 4x4 E4OD 7.3 IDI Non-Turbo
Alpiner is offline
post #2 of 8 (permalink) Old 05-07-2008, 05:09 PM
Check your return line at the back of the engine. It can leak and when you turn it off you will not see any fuel coming out but it will be there.
cur.bill is offline
post #3 of 8 (permalink) Old 05-07-2008, 05:15 PM
NCheek's Avatar
Check all of your return lines coming from the injectors, the filter, and the IP. This will most likely find your leak. The fuel inlet into the IP could be leaking, but it is more likely that it is the return lines.
-Nick
1986 F-250 2WD, Regular Cab, LWB, 6.9, T-19, Sterling 10.25", open 3.55's, XLT Lariat, Texas Sesquicentennial Limited Edition, No Restrictor Plate, manually switched high idle/advanced timing, and an awesome custom shift knob thanks to Bruce Roosa / Koolknobs.
279,000 miles and counting, hoping for a US Gear OD and a Hypermax Turbocharger one day.
My first truck:
1982 F-250 4WD, Extended Cab, LWB, 5.8, C6 to T-19 swap, BW 1345, Dana 44 TTB/Dana 60 Semi Floater, open 3.55's. About four different colors (not counting rust), currently on loan to my little brother. Maybe one day it can be home to a 6.9L too.
Work Truck:
1992 F-700 Flatbed w/ dump, 7.0L BIG BLOCK GASSER, 5-speed trans (Clark?), 26,000 lb GVWR. Rides like a tank
NCheek is offline
post #4 of 8 (permalink) Old 05-07-2008, 07:14 PM
cdnsarguy's Avatar
My Photos: (109)
If the leak is from the advance arm seal it is a simple fix by a Stanadyne or any diesel IP shop.... usually done in vehicle. Check my photo link for IP pics see if you can determine where it is leaking. If you use a piece of cardboard shoved under the IP or other paper item you may be able to find the leak.... If it is center front that would be the main shaft seal........ new IP.
Check out ...... 7.3 L Ford Diesel Fuel Injectors Fuel Pumps Accessories for a possible rebuilt IP if needed.
IP bottom - TheDieselStop.Com Photo Hosting
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #5 of 8 (permalink) Old 05-08-2008, 02:12 AM Thread Starter
Thanks to all of you for your suggestions. I am hoping it is in the return lines and not the IP.
Alpiner is offline
post #6 of 8 (permalink) Old 05-08-2008, 04:49 AM
My Photos: (27)
The main shaft seal can also be replaced once the pump is removed. It doesn't require a pump replacement.
LMJD is offline
post #7 of 8 (permalink) Old 09-03-2008, 08:54 PM
grasshopper7.3's Avatar
I loved your diagram pics. Ive been looking for the locale of my injection pump to find a small fuel smell. Thanks
grasshopper7.3 is offline
post #8 of 8 (permalink) Old 09-03-2008, 10:11 PM
Plywood's Avatar
My Photos: (13)
Soooo many ways diesel could be at those locations, but I like to start cheap, I recently purchased a "pump kit" for $5.00 from an IP rebuild shop. It has the "cheerio" shaped seals that go where the metal line from the filter to the IP has the nuts on each end, and where the return lines come together at the rear of the engine.
It also has an O-ring that goes in after you remove that metal line on the back of the pump and then remove the next nut, it, believe it or not has an O-ring in there (I didn't believe it till I saw it). Also maybe any of the injector lines at the pump could be loose.
You can get everything pretty clean with compressed air, and then you should be able to see where it is coming from, maybe try spraying a solution of water and laundry detergent with a squirt bottle and then compressed air to get it real clean.
Sounds like it's leaking fast enough to see.
85 F250 XLT Lariat 4x4 7.3L N/A, C6, 315/75/16 Siped Wild Country Muds, Manual ZD9s, K&N, Soup Bowl Out, Dura-Lift Pump, Dynomax 3" Y-pipe-4" AFE Muffler-5" Turndown.
Turn it up!
Plywood is offline
