Fuel leak - return line - Diesel Forum - TheDieselStop.com
Old 07-03-2009, 08:47 PM   #1 (permalink)
Question Fuel leak - return line
I have a fuel leak that appears to be coming from a return line where it connects to the injector. Is there a particular type fuel line that I should use to replace it?
'94 F250 4x4, Super Cab, Long Bed, Turbo IDI, E4OD, 3.55, stock, 119k miles.
texcollex is offline
Old 07-03-2009, 09:04 PM   #2 (permalink)
chuckster57's Avatar
If one is leaking then the rest are not far behind. Just get a whole kit called an injector installation kit. It will come with all new caps, O rings, line and clamps. Can be found at most auto parts stores, on-line , or E-bay. midwest fuel injection ( site sponsor) has them. I did mine about a week after I bought my truck, Very easy to do. Plenty of write up's here, but if you need detailed instructions I will be happy to tell you.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 07-03-2009, 11:13 PM   #3 (permalink)
typefour's Avatar
I have an ad in the classifieds for these. In other stuff section.
91 F350 crew cab 4x4 7.3 ats and intercooled with cut down 2000 ps cooler, bigger turbo comp,head studs, torque cam, coated rockers , balanced. very good power.
pyro,boost and all stock guages ignored with mechanical real ones
Fugitive sandrail. type 4 2840 turbo fi, lots of fun
typefour is offline
