FUEL MILLAGE AND IS THERE A BIG DIFFERNECE IN SIZE OF TAMKS.
JUST WONDERING WHAT KIND OF MILLAGE YOU GUYS ARE GETTING PER TANK WITH A LOAD ON? I'M HAULING A LOADED 55 FOOT CAR TRAILER. ONE OTHER THING IS THERE ANY DIFFERNCE IN THE SIZE OF TANKS FROM FRONT TO REAR.
1989 F-350. 7.3
GREG
1989 F-350 SPEED 7.3
EXTENDED CAB
FIRST DESIEL LOOKING FOR TIPS.
Re: FUEL MILLAGE AND IS THERE A BIG DIFFERNECE IN SIZE OF TAMKS.
cant really say what I get with a 55' loaded with cars. but I pull a 36' tandom dual trailer loaded with a tractor, cutter, bailer, chains, etc...around 25K. I get about 9-10mpg. a lot of stoppin/slowin down is involved. and i go about 65-75mph.......Gibson
oh, the tnaks are prolly 19 gallons each.......
D.T.Gibson
1.830.203.1460
new newer rig: '05 greyish/balckish Ford F-350 XLT Lariat, Crew Cab, 6.0L PowerStroke, Fx4, Leather and all the electric goodies besides a moon roof, auto trans, 3:73's, leveling kit. SCT Looney Tune stacked with Edge Juice with Attitude, and 4" turbo back exhaust. 91K.... blew HPOP and headgaskets. In shop for now. maybe by the 8th ill have her back with new long block! sweet!
newer rig: late '99 Red Ford F-350 PowerStroke, 4x4, CC, 4r100 Auto Trans, 3:73's, Stage Coach Conversion, 4" DP to 5" up to 6" stack, aFe Stage II intake, DP Tuner 4pos chip, dFUSER oil crossover line, 10K mod, AIC controller, '06 18" King Ranch Wheels. 225K.
new rig: CUMMINS POWERED '95 F-350 XLT, crew cab, Blue & white, ZF5-speed, 4x4 with auto locking hubs, 4:10 gears, 283K miles, 3" DP to 5" exhaust, Auto Meter A-pillar 3-gauge pod with EGT, Water temp and oil pressure.
MY GAUGES ON MY TANKS DON'T WORK ALL THAT WELL FOR SOME REASON, ANYWAYS, THE FRONT TANK THE OTHER DAY I GOT ABOUT 230 KM OUT OF IT AND ONLY AROUND 120KM OUT OF THE REAR AND I'M NOT SURE WHY??
EXTENDED CAB
my back tank i got 318km not loaded exept for 60km i had 18ft travel trailer in bc lots of hills. as far as the front tank i cant say as it is in my garage just picked it up new $140 cad ford was $700 ouch
1992 F350 CREWCAB 4X4 LONGBOX 7.3 NON TURBO 5 SPEED 4.10`s ( DAS-BOAT ) STOCK OTHER THAN K&N,push button,safari rack, soupbowl mod, cooper atr tires
core alum rims
There is not too much difference in the tanks quantity....
F250,Pickup Extra Cab,155 IN. WB Front - 19 GALS.
F250,Pickup Extra Cab,155 IN. WB Rear - 18.2 GALS.
F250,Pickup,4WD,133 IN. WB Rear - 18.2 GALS.
F250,Pickup,4WD,133 IN. WB,Gas Front - 19 GALS.
F250,Pickup,4WD,133 IN. WB,Trans Mfr CD E4OD,Diesel Front - 22 GALS.
F250,Pickup,RWD,133 IN. WB Rear - 18.2 GALS.
F250,Pickup,RWD,133 IN. WB,Diesel Front - 20 GALS.
F250,Pickup,RWD,133 IN. WB,Gas Front - 19 GALS.
F350,Pickup Extra Cab,RWD,155 IN. WB Front - 19 GALS.
F350,Pickup Extra Cab,RWD,155 IN. WB Rear - 18.2 GALS.
F350,Pickup,168 IN. WB Front - 19 GALS.
F350,Pickup,168 IN. WB Rear - 18.2 GALS.
F350,Pickup,4WD,133 IN. WB Front - 18.2 GALS.
F350,Pickup,4WD,133 IN. WB,Gas Front - 19 GALS.
F350,Pickup,4WD,133 IN. WB,Trans Mfr CD E4OD,Diesel Front - 22 GALS.
F350,Pickup,RWD,133 IN. WB Rear - 18.2 GALS.
F350,Pickup,RWD,133 IN. WB,Diesel Front - 20 GALS.
F350,Pickup,RWD,133 IN. WB,Gas Front - 19 GALS.
Of course if you top it off there may be a gallon more, but Ford recommends not doing that due to possible leaking of fuel at several areas.
Please stop using CAPS LOCK it's like SCREAMING ON THE INTERNET!!!!
Do a search for broken tank sender pickup tubes, they only allow 3/4 of the tank as usable fuel.
1989 F-350. 7.3
GREG
There's a lot of science in Towing and Mpg.There is a lot of things that improve mpg and there is a lot of things that cause bad mpg when pulling including the weather!
On a good dry day not going against the wind pulling a loaded 16ft tandem axle utility trailer with a 3,000 pound car on it I make around 15 or 16 mpg with my f350 93 idi.
How can you pull a 55 ft trailer on any highway when the maximum limit on a tractor trailer is 53 ft??? How is that legal?
Unless other states have different highway laws and limits [img]/ubbthreads/images/graemlins/shrug.gif[/img]?
First off, looks like he's in Canada so the trailer limit might be different up there. Also, I would like to know about that 3/4" tube. I've been told to look for it and I CAN'T find it. Is it IN the fller tube?
Rusty Red: '93 F-250 XLT xtra cab long bed. 3.55 rear end, 5 spd, 285/75/16 BFG All Terrains, 215,000 miles. Soup bowl chopped, K&N Air Filter, lots of rust.
85 Mercedes Benz 300D Turbo Diesel. 215,000+ miles (intermittant odometer), almost everything works (give me time), and $500!
They are talking about the pipe in the fuel gauge sender assembly. I don't know what the thing on the end of the suction pipe origionally looked like but I retrieved a big handful of black hard rubber or plastic debris from both my tanks. I used a 3/8 inch fuel hose adjusted to just clear the bottom of the tank. I put some screen over the hose end and clamped the screen end and inlet pipe end.
TomC
1992 F250 XLT 4X2 ZF 5 sp. 4.10 gears,towing pkg.
the usual factory bells and whistles 195,000+ mi.
would that be why my tanks only seem to hold about 14 gallons in one and 12ish in the other? I've always figured i had a ton of crap in my tanks. I haven’t dropped them to look yet. But when my tanks get low my gauge vaguely tells me that I’m almost empty. I read in my owners manual that i (if i remember right) should have a 19 and 18 gallon tank.
Tyler
89 F-250HD 7.3L XLT Lariat 4x4, 5spd, 4.10 rear - ~200,000 miles
Best mpg - 17.5 (drafting behind a semi doing 65) My Truck Pics
