Re: fuel pedal for cold start
Instructions for starting on sunvisor say 1/2 throttle for starting above freezing, full throttle for starting below freezing.
My observation has been mine is just fine if I cycle the glowplugs twice with a 10 second wait between cycles (let plugs cool off, transfer heat to combustion chamber), then just press and release to set fast idle and crank. It fires after less than 2 revolutions with 2 cycles of the GPs. Yours may or may not need 2 GP cycles, mine has to crank for 3 or 4 seconds to start with only 1 GP cycle, and glow plugs are cheaper than starters...
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
