Old 01-01-2008, 08:21 PM   #1 (permalink)
Fuel pressure
Hi All. 2 questions.
What should the fuel pressure be at the filter test port with the engine running?
Out of nowhere my engine started surging at idle, no leaks, timing right, fuel pressure at 3 psi running, at the filter. Too low?.thanks
73 f350 flatbed, 7.3 diesel ,np 435 trans ,spicer 3 speed aux, dana 70u axle. beefed up overload springs. crane . dual tanks, single 3 in exhaust stack.
scavenger is offline
Old 01-01-2008, 08:37 PM   #2 (permalink)
Re: Fuel pressure
It should be 5 to 7 lbs running.
icanfixall is offline
Old 01-01-2008, 09:29 PM   #3 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
Re: Fuel pressure
pressure too low..starving for fuel
your lift pump could be going out.
1997 F-350, XLT, dually, crew cab, 7.3 PSD, E4OD auto, B+W turnover goosneck hitch, ts 6 pos. chip,
http://community.webshots.com/user/91diesel
**91diesel AKA anthony2010**
http://www.youtube.com/watch?v=fe622W_yZcQ
16.66MPG
[IMG src=file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-9.jpg][/IMG]
91diesel is offline
Old 01-02-2008, 02:30 AM   #4 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Fuel pressure
Do a pressure and flow test of the fuel pump at the Schrader valve on the filter header (FSS- fuel shutoff solenoid disconnected on IP). Remove the tire valve core and hook a hose and pressure guage on it should see 4-6 psi when cranking. Then do a fuel quantity test same place, should see 1/3 pint in 10 seconds of engine cranking, route fuel to a suitable container with a hose.
If there is a problem with the lift pump and you are changing it, ensure the new pump comes with instructions as to correct installation procedure if it is the newer model pump with the almost straight arm.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 01-02-2008, 12:30 PM   #5 (permalink)
Re: Fuel pressure
I'm running an electric pump, When running, and I pinch off the return at the filter, pressure goes up to 6 psi and the engine runs only slightly better. The fuel pressure has allways been around 3 psi. I found a referance to pressure elsewhere in this forum that says 1-2 psi at the shrader valve. so I,m a bit confused. I suppose I should be a little more clear as to how it runs. There are no issues off idle and hi speed. it will idle smooth for a few seconds the it will jump a few hundred rpms for a split second then go down again for a few more. this is not a rythemic type of action. sometimes it will stay at the higher speed for several seconds then drop down to idle again. I read about a slipring in the govorner that breaks up but found no black particals inside. Could I simply be having govorner problems with the ip now
Old 01-02-2008, 12:49 PM   #6 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Fuel pressure
Remember that the return to #1 injector and the inlet to the IP are free flowing all the time.... the IP rally only needs 2 psi to work correctly. The extra pressure and flow are used for cooling the IP. Your rythmic surge could be air in the system..
