fuel pressure - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 04-08-2010, 09:40 PM Thread Starter
fuel pressure
Does anyone know what the fuel pressure should be at the fuel filter of my 1990 F250 7.3 idi. I have about 3lbs. at idle. This seems low ?
rusty6977 is offline
post #2 of 4 (permalink) Old 04-08-2010, 10:18 PM
chuckster57's Avatar
IIRC when you test the pressure/flow 4-7 PSI at the schrader valve is specs. 3 PSI might not be "bad" . You have to remember the IDI has a mechanical pump and it doesn't have to pressurize the fuel system- the IP does that.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 4 (permalink) Old 04-08-2010, 11:07 PM
Plywood's Avatar
My Photos: (13)
Depends on who you ask I guess, but I've never seen anything down to three.
Thing is, you never know exactly how precise your gauge is though.
I would try revving it and see what happens. If the pressure gets down to low at higher rpms it is bad for the transfer pump in the IP. A lift pump is much cheaper.
85 F250 XLT Lariat 4x4 7.3L N/A, C6, 315/75/16 Siped Wild Country Muds, Manual ZD9s, K&N, Soup Bowl Out, Dura-Lift Pump, Dynomax 3" Y-pipe-4" AFE Muffler-5" Turndown.
Turn it up!
Plywood is offline
post #4 of 4 (permalink) Old 04-09-2010, 04:01 PM
cdnsarguy's Avatar
My Photos: (109)
The pressure is normally stated as 4-6 psi however there are absolute minimums......
Fuel: manual lift pump pressures.
Filter inlet min. ( lift pump to filter ) - 2.0 psi
Filter Outlet min. ( filter to injection pump ) - 1.0 psi
Note:
Most 6.9s-7.3s have at least 3 to 5 psi taken at the Schrader valve with core removed.
Volume is just as important, Specs are 1 pint in 30 seconds at 675rpms running or 1/3 pint after 10 seconds of cranking*** only, taken at the Schrader valve with the core removed.
*** FSS wire disconnected
Proud Canadian BOOB man too!!
cdnsarguy is offline
