Old 07-30-2008, 10:32 PM   #1 (permalink)
rednexx's Avatar
My Photos: (17)
Fuel return line to tank
Is this actualy needed? The reason I ask, is that I'm doing a 7.3 IDI swap into a old school 460 gasser.
The gas pot has a fuel switcher, but doesn't have any return lines (carburated) and no provisions for it on the fuel tanks.
I run large generators all day (old doitz diesels) that don't have returns back to the tank. They return to the filter housing only with no problems. They are fed with a Carter electric that probably out out 7-9 psi.
The manual pump on the 7.3 would do the same (I think) as a manual on a gas pot, and just pump all they can and bypass internally.
I'm just trying to figure out if I have to drop both tanks and put return line in and change over the switcher to a return style also.
Thanks for the input in advance!
Early 99 F-250 Superduty X/C SB, 6 speed, South Bend Con OFE clutch, 4" turbo back exhaust, Ebpv Brake Mod, DIY Tymar, Hutch Mod, 2" leveling kit, 315/75/16's, DP tuner (stock, 60tow, 80econo, 120race, 140extreme), Warn premium hubs, Autometer pyro, boost and fuel pressure gauges.
76' (updated) E series 24' Motorhome - 89' 7.3IDI w/ATS turbo, ZF 5 speed, LUK clutch, dana 60 front, 3.73 gears, 245/75/16, 4x4, almost complete.
My Gallery
http://photos.thedieselstop.com/show...0/ppuser/80710
Next........MORE!!!:
rednexx is online now
Old 07-30-2008, 10:52 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
The returning fuel was/is used to cool the IP and injectors so I would say it is required to return to the tank(s) ......... the lift pump does not to my knowledge bypass internally. Our system is a completely sealed circuit.. tank to pump/engine and back to tank. Pump handles 28 GPH at 4-6 PSI in a complete circle.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 07-30-2008, 11:24 PM   #3 (permalink)
rednexx's Avatar
My Photos: (17)
Thanks cdnsarguy. On a manual or electric fuel pump without a return, they must bypass internally or they would quit the first time you dead headed them (I would presume). So, if I ran an elecric pump without a return, do you think it would be a problem? I also have a Hino diesel that has a manual pump and there is no return on it also.
I can understand the cooling issue to a point, but the superduty's actually heat the fuel in the filter body.
I'm just trying to get out of a lot of mods that I may have to do.
Thanks again
My Gallery
Old 07-30-2008, 11:26 PM   #4 (permalink)
arthurgoboom's Avatar
The return to tank is also used to flush any air bubbles out of the fuel line before they reach the injection pump. It's supposed to be free-flowing, if you connected the return only to the filter head nipple the entire return system would be under 4-6 psi.
As for deadheading the pump, the mechanical pump will just not let the diaphragm spring decompress if the line is overpressured. The pump actuation arm will just float free. Any diaphragm pump (electric or mechanical) can handle deadheading just fine. Vane/gerotor pumps like a holley don't like it though.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 07-30-2008, 11:33 PM   #5 (permalink)
rednexx's Avatar
My Photos: (17)
Seeing that the Fuel filter system is alreay being fed at that pressure, and you are only feeding it back at the same, would it be any problem?
The only drawback I can see is that it would be tough to bleed the system if you ran out of fuel.
It's happened to me a few times on my rigs, and it can take a while for them to clean up.
My Gallery
Old 08-02-2008, 09:40 PM   #6 (permalink)
rednexx's Avatar
My Photos: (17)
Anyone else have any ideas/thoughts/input on this? I'll probably be dropping the tanks anyway, but just curious if it is really needed.
Thanks for the input.
My Gallery
Old 08-03-2008, 09:48 AM   #7 (permalink)
danngreen's Avatar
I've only heard about looping diesel instead of using a return, havent seen it or tried it, but the SVO guys say its a bad idea because the fuel will get too hot which causes something called "low lubricity". the return gives it a chance to cool. good luck.
My first project truck: '90 F250 7.3L IDI 2WD, camper shell, primed and ready to pick color(s). Dual exhaust
WORK DONE: replaced starter, new return lines/injector-caps, new glow plugs/wiring harness/controller-relay, wiring fixes, replaced brake cylinders/pads, two-tank SVO conversion
danngreen is offline
