Fuel selector valve - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 05-15-2006, 09:32 PM Thread Starter
Fuel selector valve
I have a 1990 7.3 question. For the past month or so when I was on the front tank the truck would run rough (surging) ran fine on the rear tank. Now it doesn't run at all on the rear. I was told that the problem was most likely the selector valve rather than the sending unit. Does this sound correct?
blacktop is offline
post #2 of 10 (permalink) Old 05-15-2006, 11:09 PM
cdnsarguy's Avatar
My Photos: (109)
Re: Fuel selector valve
PM me your email addy and I will send the FSV test......
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 10 (permalink) Old 05-16-2006, 04:27 AM
HamerDown's Avatar
Why not post it so we all have it... [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/wink.gif[/img]
88 F 250 7.3 Super Cab XLT Lariat4X4...Cream Puff
81 Corvette...Pampered
Harley Shovel 88" Show Stoper...WOW
BBC 468 Jet Boat...Gotta get Wet!
It's the Women that cost me the $$$$
HamerDown is offline
post #4 of 10 (permalink) Old 05-16-2006, 04:39 AM
cause most the time pete's info contains pics and alot of literature to follow up on. When he has time he will rather pm them than try and hassle TDS forums to get the images loaded correctly. Thanks pete for all of you help over the time!
--Ryan
91 f-350, dually, 7.3 diesel. 2wd, 4.10 gears LS. E4OD. New injectors, lift pump, and fuel filter at current 85,000 miles. Autometer pyro and fuel turned up. 3" exhaust with walker "btm" muffler
olivera149 is offline
post #5 of 10 (permalink) Old 05-17-2006, 06:15 AM Thread Starter
Ok, did the tests and the valve motor apperars to be activating when I flip the switch. Is the next thing the sendig unit?
1990 Ford F250 7.3L
blacktop is offline
post #6 of 10 (permalink) Old 05-17-2006, 08:27 AM
cdnsarguy's Avatar
My Photos: (109)
If your positive there is enough fuel in the tanks then surging would indicate air intrusion or low fuel. There could be any number of areas where air can enter and not allow the fuel to be lifted by the lift pump be it manual or electric.
Do a pressure and flow test of the fuel pump at the Schrader valve on the filter header (FSS- fuel shutoff solenoid disconnected on IP). Remove the tire valve core and hook a hose and pressure guage on it should see 4-6 psi when cranking. Then do a fuel quantity test same place, should see 1/3 pint in 10 seconds of engine cranking, route fuel to a suitable container with a hose.
Tank lines have known to crack or break off... at the sender
The rubber hose at the lift pump can deteriorate........
Holes can be worn in the steel lines only takes a pin hole.... check them from front to back......
Clamp off the rubber line to fuel filter from #1 injector...
Sorry process of elimination......
Check out this page too.......
http://www.intellidog.com/dieselmann/idi.htm
I have some good scans from manuals, pages of info/pics saved from TDS members gallery's and cannot post them all in my gallery... so if you want something tell me what and PM me with an email addy. If I have it you can have it too if it will help.
I felt like a one armed paperhanger for the past several weeks as my best scanner I used with 98 will not work with XP. Got a new scanner yesterday....... [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
post #7 of 10 (permalink) Old 05-17-2006, 08:53 AM Thread Starter
Thanks for the info...am I correct in assuming that if there is a cracked line it would be between the selector valve and the front tank since it runs fine on the rear. The strange thing to me is it would run (but surge) until I took the line off of the sending unit to inspect it and when I put it back on it won't run at all. Is it possible that it's not getting a good seal at the sending unit?
1990 Ford F250 7.3L
blacktop is offline
post #8 of 10 (permalink) Old 05-17-2006, 09:01 AM
cdnsarguy's Avatar
My Photos: (109)
There is an oring in each of the line connectors and yes if the oring dislodged/cracked then your not getting a good seal possibly. Use some grease when reassembling anywhere orings are used. Fuel line repair parts are available at A/P stores.
post #9 of 10 (permalink) Old 05-18-2006, 09:50 AM Thread Starter
Ok. I took the line off of the sending unit and stuck it in a bucket of fuel and it drew it from that fine...put the hose back on the sending unit, won't run. The fitting really doesn't seem to seal good on the sender so I was thinking of trying to run a new line from the front tank to the selector (using hose clamps) to see if it draws, if it does it would lead me to believe it is not seating good. Do I need to use a 3/8" rubber hose for this?
1990 Ford F250 7.3L
blacktop is offline
post #10 of 10 (permalink) Old 05-18-2006, 10:36 PM
cdnsarguy's Avatar
My Photos: (109)
I would think so if it is a 3/8 line.......get good fuel line clamps or very small/narrow screw clamps
