Old 01-27-2007, 11:35 AM   #1 (permalink)
fuel system problem
Hey all,long time reader of this forum - 1st posting.Great stuff.I've been able to keep my 93 well maintained for the last year or so with the help of reading past forum postings. I started my truck the other day. gp's cycled fine.fired up and quit after maybe 8-10 seconds. There she sits crying for some attention. My plans today are to check flow from the lift pump but since i'm getting nothing out the exhaust, could it be the fuel shut off solenoid ? I checked and replaced 3 gp's last month and has a new fuel filter. Traced my fuel lines front to back and they seem fine. Tank is 3/4 full. Starter and batteries are strong. Any advice would be appreciated. Thanx.
pistilnoon is offline
Old 01-27-2007, 12:19 PM   #2 (permalink)
Re: fuel system problem
Why check, it is too cheap, too easy to replace.
How old is the lift pump?
How long do you expect a lift pump to last?
Would you believe (IMO) that a lift pump older than 60,000 miles is subject to failure?
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
Old 01-27-2007, 12:31 PM   #3 (permalink)
not sure how old. I've put about 15000 mi. since I bought it a year ago. Wouldn't be surprized if it was original ! I know the previous owner and he admits doing the bare minimum as far as maintaining. Good advice. Little $$$ for piece of mind. Thanx
Old 01-27-2007, 11:40 PM   #4 (permalink)
My Photos: (17)
Check the electrical connections from the loom to the IP. You might have knocked one loose. Sometimes making a connection, sometimes not. you'll only notice the "SOMETIME NOTS". [img]/ubbthreads/images/graemlins/smokin.gif[/img]OkieGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 01-28-2007, 02:06 AM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Sounds like a fuel problem..... probably air entering the system. When you traced the lines did you move any of them, how about accidently when you did the GPs.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 01-28-2007, 11:54 AM   #6 (permalink)
thanks for the advice.I checked flow rate of lift pump and its fine. I also checked fuel shut off solenoid and its fine also. Lucky for me it decided to die in my driveway and not up the mountain where I was heading. guess the only good news - i'm learning ! i'll be checking electical connections next.
Old 01-28-2007, 12:02 PM   #7 (permalink)
My rig still has the origional lift pump from the day she was born. She has 143,242 miles on it and is still running strong. Though I do expect it to go some day because I do notice a little weariness from the lift pump. I would assume that it would be in my best interest to install a new one soon. But so far so good. Aint that something??? Actually I been just waiting to see how far it will go before failing because of the miles I got on it.
I do have a rebuilt IP, new injectors,new starter and new batteries theyre about 4 yrs old,batteries are 1 yr old and on the second set of GPs this last summer. Starts and runs good thus far.
I just thought Id chime in on the longevity of my lift pump... [img]/ubbthreads/images/graemlins/smokin.gif[/img]
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
AmaMoparmanbutlikeForrrrrdtrucks
truckdrivindave is offline
Old 01-28-2007, 01:29 PM   #8 (permalink)
Dave,
My experience was similar, the original was replaced as part of a I/P re-build, this was at 130,000.
At 260,000, I have replace the lift pump total of 3 times, twice after the I/P re-build.
Good Luck
BB
Old 01-28-2007, 07:09 PM   #9 (permalink)
again, thanks for the tips. i've learned to never rule anything out. Okiegringo was bang on. found a dead fuel shut off solenoid on my ip. hopefully i can find one - no luck at our local parts stores. Maybe International can help.
Old 01-28-2007, 08:17 PM   #10 (permalink)
This post may help finding one. You'll also find some advice on removing the top and putting it back on. The top has to come off to get to the FSS.
Best of luck,
Devo
Work like there is a tomorrow and play like there isn't.
87 F250 Lariat SC LB 4X4 with an NA 6.9, C6 and 4.10's. Dana 50 IFS up front. 244K mi. 3" exhaust, WVO, Ram air. Thinking about propane or methanol/ water...
First diesel and a lot to learn....
96 F350 CC LB 4X4 AT 231K
Second diesel and still a lot to learn...
DevoK12RS is offline
Old 01-28-2007, 08:25 PM   #11 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Visit the closest Stanadyne shop in your area.....
http://www.stanadyne.com/new/index.asp
Old 01-29-2007, 04:36 PM   #12 (permalink)
installed new fss today.good news is that its working and getting fuel to injectors.bad news is i keep frying 20 amp fuse on my gp circuit.maybe broken gp wire grounding out ? any advice ?
Old 01-29-2007, 05:59 PM   #13 (permalink)
You have a wire shorting out somewhere. The actual wires going to the GP's don't have fuses, your fuse is probably for the "ignition" circuit which powers the FSS, advance, idle up and GP controller.
Follow the wire harness and see if the wires are touching any metal anywhere. Also the advance solenoid or idle up solenoid could be shorted out, you can just disconnect them to eliminate those as problems.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 01-29-2007, 08:14 PM   #14 (permalink)
arthurgoboom's Avatar
If it was me, I would disconnect the FSS wire, MAKE SURE THE IGNITION IS OFF, and take an ohmmeter and connect black lead to battery ground, and probe the FSS wire. Make sure that's not showing any continuity. If that shows anything other than open circuit, that'll tell you if you have a short in the wiring harness somewhere.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 01-29-2007, 10:01 PM   #15 (permalink)
It would have to show zero resistance for that to work. You will get continuity through the other solenoids.
» Network Links
»Ford Car Reviews
