Fuel Tank Venting - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 01-27-2008, 10:38 AM Thread Starter
Fuel Tank Venting
Are the fuel tanks on 89 f350 vented anywhere? why or why not?
Thnks remote
Remote95 is offline
post #2 of 5 (permalink) Old 01-27-2008, 10:48 AM
BlueMule's Avatar
My Photos: (12)
If they are like the 94-97 PSD's they are vented through the fill hose/fill neck. They use a hose within a hose. There is a soft sleeve type hose within the stiff outer hse. The fuel enters the tank thru the inner hose and the air vents thru the space between the two hoses.
Rodney#33
BlueMule is offline
post #3 of 5 (permalink) Old 01-27-2008, 10:54 AM
BlueMule's Avatar
My Photos: (12)
Are you having trouble with your tank being slow to fill and shutting of the nozzle at the pump? If so DZLJIM has a writeup that shows how to modify the filler necks to take the fuel faster.
1994-1997 Power Stroke FAQ - Fuel Tank Vent Mod
Rodney#33
BlueMule is offline
post #4 of 5 (permalink) Old 01-29-2008, 09:29 PM Thread Starter
No problem filling, etc. The question is asked because of a problem I have posted on before and have not solved. When running on one tank the truck runs fine but when switched there seems to be I believe a fuel shortage after a period of time. Seems to get worse aS fuel is depleted in tank. Replaced both sending units at same time few months ago, Dont think problem can be there. I was wondering about venting becasue this is the F350 that I added flatbed body and used filler tubes that came with it, as best I remember. The flatbed body came off of wrecked chevy 1 ton. Problem I suspect is either Air in system when running on that particular tank or lack of air when running on that tank. I have checked for everthing to see if air is entering system. I dont know about venting and how that would affect this tank?
thnks , Remote
Remote95 is offline
post #5 of 5 (permalink) Old 01-30-2008, 09:17 AM
My Photos: (27)
Since you have a non stock filler without the vent tube, I'd bet that's your problem. Through the years I've actually seen a few of the old metal fuel tanks sucked down and collapsed from someone buying a non vented tank cap and using it. I'd buy a vented cap and see if that helps.
LMJD is offline
Similar Threads
fuel tank spits and sputters on front and runs perfect on back tank mastkiss1234 Power Strokes 1994-1997 General 1 06-24-2007 03:23 AM
fixing hole in front fuel tank or aftermarket plastic tank manleyjt Power Strokes 1994-1997 General 4 01-21-2007 04:03 PM
fuel tank sender 1987 E 350 6.9 Dual Tank clueless1 6.9L IDI Diesels (Not Power Strokes) 4 11-06-2006 04:34 PM
Venting(Harpoon?) of 38 gallon fuel tank CaptSkup 1999-2007 General Questions 17 03-28-2005 08:02 PM
Venting(Harpoon?) of 38 gallon fuel tank CaptSkup 6.0L Power Stroke Engine and Drivetrain 0 03-24-2005 01:12 PM
