I am trying to find someone with a 5-speed who has 4.10 gears and 33" tires. cause i am looking at regearing the truck to take off better using second gear and im running 285-75R16 tires and i have 3.73 right now with my 5-speed and i was wondering if anyone had it so i could see at what the diffrence in rpm ranges and the top speed diffrence.
thanks alot
1993 Ford F-350 IDI Diesel Crew Cab LWB Banks Sidewinder, Dual side exit 5" Exhaust, Soft Bed Cover, 2WD, Ranch Hand Front and Rear Bumpers, Boostlevel=14psi, 5speed trans, 2800 watt sound system, RedTop Holley FuelPump, 181,000 miles
250HP and 550 Torque @Wheels (w/o NOS) http://community.webshots.com/user/coolmann64
2003 Excursion Limited powerstroke, bd-power 80hp chip, single ATS exhaust, air intake and tv/dvd
I have 285-75R tires, 5-speed and 4.10 gears and get 57 mph at 2000rpm. I always start off in 2nd w/ no problem, unless I'm towing or starting up a steep hill. Then I use 1st. Don't know if that helps, but I'd like to change to 3.55 or 3.73 gears for a little better mileage.
Mike [img]/ubbthreads/images/graemlins/shrug.gif[/img]
91 F-250 XLT, 4x4 Lariat-sc,7.3IDI,hypermax 1.0 turbo w/3.5 exhaust, 3A-pillar w/ digital pyro+boost+oil press gauges, 5spd ,TransferFlo 40gal midship tank, Pre-Luber, 4.10 diff., front add-a-leaf, 3 Frantz tp bypass oil filters in parallel, LUK single mass fly-wheel, push-button constant duty glow plugs.
On my truck I used to have an E4OD and a 3.55 rear axle running the stock 235 / 85's. It felt like I had way too much top end and not enough power starting off. I simultaneously switched to a PSD 6 speed ZF and 4.10 rear (same tires) and now feel that was too big of a jump. I think a 3.73 would be perfect for me... It doesn't hurt that I have so many low gears now with the ZF6. But, I am almost always in OD now if I'm going over 40mph...
To see how different gearing / tire size combos affect engine speeds try this RPM / MPH CALCULATOR
Jason
Early 99 F350 CC Dually 6 speed - just acquired with only 290,000 on the odometer... Build date of 11/98. '91 F250 standard cab, 3 E4OD's in first 100k, Hypermax turbo, 99 powerstroke intercooler, 6 yes 6 speed ZF tranny installed at 100k miles!!, '99 E-350 ambulance disc brake, limited slip, 4.10 rear end 1983 Ford Ranger Diesel - 2.2l Mazda engine, custom built 5 speed using RX-7 parts, custom built ex manifold to add a variable nozzle turbo off a Mercedes, homebuilt 2 tank WVO system
1946 Dodge COE 1.5 ton in process of restoring and repowering with Detroit 4-53 turbo and Road Ranger 610. My shop
Mike
Same here except 235/85R16s (pretty dang close circumference wise I think [img]/ubbthreads/images/graemlins/shrug.gif[/img] )... depending on how much grade is in front of me at the time, I occassionally use 1st to get rolling.... other than that, usually 2nd to start off in.
Best as I can tell... 13-15mpg in town and around 16-17mpg on the highway (*ain't* complaining! My brothers 2500HD w/8.1L gasser gets 12-13/8 towing! [img]/ubbthreads/images/graemlins/eek.gif[/img] )
