Glass Pack? - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 04-22-2006, 07:03 PM Thread Starter
Glass Pack?
I am replacing my stock muffler with something cheap till I get the cash for a turbo. Will a glass pack be to loud? Any of you run one, if so how is it? And what about the walker big truck muffler, is it straight threw? Thanks.
Jimmy C.
89 F350 7.3 IDI Diesel, Black and silver, single cab long. 4x4 XLT Lariat. 5 Speed Manual, Banks sidewinder turbo, 4" skyjacker suspension kit with rear add leafs. Chrome Pro Comp wheels, 35" Pro Comp Mud Terrains. ---In the process of complete exterior strip for some new paint and chrome all the way around.
JCDiesel89 is offline
post #2 of 11 (permalink) Old 04-22-2006, 08:00 PM
Re: Glass Pack?
Wierd enough I once put on an old cat D2, and it made it really quiet, put another one on an old case 310 and made it quiet as well, and then I put one on a gasser car and it was loud as hell, dont ask me why, but they have a different effect on diesels. (my experience)
3 X 06 Ford F250s 6.0 stock 4X4, just got two more, so now 5!
2003 Ford F250 4" Lift, Chipped, 4X4, Diamond Box
2000 Ford F250 7.3 PSD, 4X4, Stock
1999 Ford F350 7.3 PSD, SRW, 4X4, Chipped
1994 Ford F250 7.3 IDIT, 4X4, Pump cranked way up, fuel milage down way low, 6 inch lift on 315/75r16, still rides like a caddy for its day.
And I grow asparagus.
cwatanabe is offline
post #3 of 11 (permalink) Old 04-22-2006, 09:52 PM
My Photos: (5)
Re: Glass Pack?
Although not as cheap as a cheap glass pack muffler a Gibson muffler is staright through and not real loud like a glass pack. It sounds better than a stock muffler. If you were to do that you could always use the muffler with the turbo also.
My sig has the link for Gibson if you want to look at there site.
1991 Ford PL Custom Ambulance Type III 7.3L Diesel.
Pioneer AM/FM/XM/CD Stereo. Code 3 lightbar, Whelen Strobes and flasher lights. Whelen flood lights on front, rear and sides. There bright enough to turn darkness into daylight. Siren with several tones plus electronic airhorn and PA. Custom 3" exhaust from manifolds back with a
. Dual alternators and dual sets of batteries. If I need a jumpstart all I do is push a button. On spot tire chains that install and de-install themselves at the flip of a switch. Also has air compressor on board along with suction unit and O2 system.
1972 Cadillac Hightop Ambulance by Superior Lucky if I get 10MPG
CompuDoc is offline
post #4 of 11 (permalink) Old 04-22-2006, 11:53 PM
Re: Glass Pack?
My buddy runs a glasspack on his 6.9, mine is straightpiped(broke off in front of the muffler really...) Mine sounds like a gas bigblock with glasspacks, his, is quieter, and all the crackle is gone, and it's a low deep sound, like you get with a turbo muffler.
Very strange, considering my 460 got markedly louder over straightpiped with glasspacks.
96 F250HD 4x4 PSD/ZF5 etc...
92 W250LE 4x4 CTD/G360/205... Transmission eater...
86 F250HD 4x4 557/T19/1345/10.25/Dana 60...
86 F250HD 4x4 6.9/T19/1345/10.25/D44HD
82F100SWB is offline
post #5 of 11 (permalink) Old 04-23-2006, 03:43 AM
Re: Glass Pack?
I replaced my muffler with a walker BTM and i love it. It is a straight through muffler and the BTM makes the IDI growl. At constant RPMs it sounds like a old cat front loader. I did notice a little better fuel economy on the highway along with more power. I chopped the old muffler off and replaced with the BTM in stock position and ran 3" pipe up to the Y pipe and used a 2.5-3 reducer and kept the stock tailpipe. After a couple minutes chopping everything and my friend welding the new unit on we were done in less than hour.
As far as the sound, its no different in the cab, until you put the windows down then you can hear the growl, but its not very noticable until 2000rpms WOT.
I got mine at napa, but i think summitt caries them too, fyi heres the part #
3"-21468
3.5"-21470
91 f-350, dually, 7.3 diesel. 2wd, 4.10 gears LS. E4OD. New injectors, lift pump, and fuel filter at current 85,000 miles. Autometer pyro and fuel turned up. 3" exhaust with walker "btm" muffler
olivera149 is offline
post #6 of 11 (permalink) Old 04-23-2006, 09:20 PM
Re: Glass Pack?
I have a 3 inch pipe and glass pack. Not bad in cab but pretty loud under load for whoever the pipe is pointing at.
'06 F250 Crewcab King Ranch 4X4 auto Black 6.0 stolen 12/31/14
by clifford bledsoe.
'09 Cameo 5thwheel home while working
'02 Eddie Expedition
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'96 IH 7.3 4700LP field mechanic
'84 Bronco II 2.8 4 speed 4X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
'76 F250 4x4 standard 360 Highboy
mont91 is offline
post #7 of 11 (permalink) Old 04-23-2006, 09:55 PM
pontoonrob's Avatar
Re: Glass Pack?
[/ QUOTE ]Me too! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]Mine sounds just right!---Rob
Cool 1988
F250,4x2 XLT extended cab,rebuilt 444cu inch,naturally aspirated IDI,5speed gearrower,aluminum radiator,facet dura lift "trans/cold"electric lift pump,99%pure virgin lead batteries,13" Sachs clutch,exhaust brake,lighted running boards,cab roof lights,! cb radio,guage whore
,dueling pyrometers,-- persons+engine+gear=6990lbs!13-19mpg.
pontoonrob is offline
post #8 of 11 (permalink) Old 04-25-2006, 02:30 PM
Re: Glass Pack?
I have dual 2" pipes with 18" long glass packs. It's pretty loud and crackles from 2200 rpm on up, especially under load. It's kind of obnoxious, but I like it! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
'88 F-250 7.3 IDI N/A, 4x4, ZF-5, 3.54, 285/75/R16 All Terrains, bowl removed, dual 2" custom exhaust with glasspacks (very unique sound)
'93 F-250 7.3 IDI N/A, future project
'88 F-250 7.3 IDI N/A, **spare parts**
'92 F-350 7.3 IDI ATS Turbo, 4x4, 4-door, ZF-5, 3.73, turned up pump, ISSPRO gauges, 6" I-beam bumpers, 35" Buckshot Mudders, custom 4" straight exhaust
'89 Bronco - future 7.3 conversion
faz_fordfreak is offline
post #9 of 11 (permalink) Old 04-25-2006, 04:10 PM
Re: Glass Pack?
I liked the sound of the glass pack on mine with the turbo also. And it was the $15 special of the week!
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
post #10 of 11 (permalink) Old 04-25-2006, 06:59 PM
Re: Glass Pack?
Come on people, straight pipe, run it all the way to the back and the in cab noise change if very little unless your are next to a concrete wall on the freeway or something.
post #11 of 11 (permalink) Old 04-26-2006, 01:07 PM
Re: Glass Pack?
I spend most of the time pulling the TT now days, and straight pipe was too much on those long days pulling. Just my age catching me I guess?
DSBlack is offline
