Old 03-16-2005, 09:42 PM   #16 (permalink)
d9d
Re: GLOW PLUG ANALYSIS
yah, let us know the result, for sure !
I'd be real curious.
I don't think they there's much resistance change until the temp starts getting up there...hundreds of degrees.
In any case, I don't see how any change would mitigate against using an ohmmeter anyway. If the change between -30 and +80 is from 1 to 2 ohms, then the test-spec is "should be between 1 and 2 ohms". That certainly ain't any less precise than a test-light! [img]/ubbthreads/images/graemlins/grin.gif[/img]
When I advise people on GP testing, I refer to a regular DMM, cuz that's all that 99.5% of people have; but I'll fess up that I don't test 'em that way myself much.
I do it with a DC clamp-on current meter. That helps pinpoint the internally shorted ones, i.e. the ones that test good with a light but don't actually heat; because a shorted one will draw different current than the other 7 good ones; and won't have any time-constant, i.e. no change in current over time, as a good plug has.
My Rig: 1991 F350, 4x4, 5-spd, 7.3na, 4.10 solids, std. cab, flaking factory blue... [img]/ubbthreads/images/graemlins/grin.gif[/img]
My other diesel is a...
Hydra 35-ton Excavator, 6V71T; Isuzu C201 genset;
'71 VanPelt Pumper, Cummins 855 Turbo
There used to be a link here, to some useful IDI-diesel tech info; but it was chopped out by others, in a vain attempt to repress the very essence of the internet: linking!
sigh...
d9d is offline
Old 03-21-2005, 02:01 PM   #17 (permalink)
My Photos: (13)
Nothing underthe hood other than the vacuum buzzer was damaged!!!! The problem I am having is the after glow cycle of the plugs. What determines or tells the relay when to open and close, heat and not heat, the plugs??? Control unit was replaced 6 months ago so it should not be bad. Could the relay on the control unit be causing my problem??? Gotta be something simple because within 6 months the control unit was replaced new total unit relay and all, the glow plug harness was replaced and all glow plugs were replaced with berus. I am about to go crazy chasing this problem. It seems after all I have replaced the truck would fire up no problem but its just not happening.... [img]/ubbthreads/images/graemlins/confused.gif[/img]
1989 F250 single cab 2WD
7.3 IDI with 150,000 miles
Single Straight Exhaust with 4" Chrome Tip
No Soupbowl
E40D
LT 265/75/16 Yokohama AT's on 16x7's
Factory Hubcaps
Gooseneck hitch
Homade rear pipe bumper with built in utility-lights and D-rings
Diamond Plate Aluminum Toolbox
Tinted Windows
Future mods: Roof Markers and front pipe bumper
1997 F250 Extended cab 4x4
PowerStroke Diesel, E40D, Manual Hubs
All Stock Except Exhaust - No Cat, 18" Glasspack
welder79 is offline
Old 03-21-2005, 03:00 PM   #18 (permalink)
the controller measures the resistance through the glow plugs. so basicly the gps change resistance from cold to hot. when they are cold the controller reads that and keeps them on accordingly. when they are hot the controller reads the resistance and cycles them less. when you have 3 or more glow plugs bad on a cold motor the controller thinks the motor is hot due to less resistance and it wont hold them on.
88 F-350 4X4 DUMP
NITROUSN is offline
Old 03-22-2005, 06:27 PM   #19 (permalink)
Do you start to crank as soon as the light goes off and hold the go pedal down half way while cranking, if so, how how does it take to fire, if not, try it?
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
