Glow plug harness - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 06-28-2005, 03:15 PM Thread Starter
Glow plug harness
Replacing the glow plugs in the van last evening I discovered that in a previuos life the boots had crumbled. Are there replacement boots or do we just live with it. I'm afraid to ask about the cost of a new harness. Wondering if they can be machined out of another material that can withstand heat a little better. Just thinking. Open to any thoughts on what I should or could do. Oh, the good news is they all came out without a problem. A mixture of Buru, Champion and Autolite. Just lucky I guess.
Thanks,
Doug
'86 F-250 4x4
'89 E-250 ATS
Doug Bensen is offline
post #2 of 7 (permalink) Old 06-28-2005, 05:13 PM
My Photos: (24)
Re: Glow plug harness
look for a jyard in your area and you should find a harness in good condition. that is the cheapest way to get one, i don't know of making it your self.
Exekiel.
Was -
12/92 f350 jasper 7.3L
Is
12/92 f350 - 4.10 open, DRW CC with 5.9l CTD BANKS IC.
Getrag 360
- exekiel
system (Fleet-guard filter and dca)
- Agnem starting system :-)
BOOB Man
exekiel69 is offline
post #3 of 7 (permalink) Old 06-28-2005, 08:29 PM
You can solder on some connectors and heat shrink. I think a new harness is about $175. Tim
'94 F250, 4X4, 7.3, E40D, 4.10, 147K
tim94f250 is offline
post #4 of 7 (permalink) Old 06-28-2005, 10:05 PM
Gibson's Avatar
I just took apart the whole wireing harness on my controller recently. there is only one wire that goes to the plugs themselves. its the brown wire coming off the controller. just take the plastic top off the controller, unplug all plugs and take out of the plastic tubing. the wire is just taped the to others to make a bundle. all the plug wire is, is one wire thats split into 4 to go evenly to the plugs. probably 6' of wire and 8 connnecters. about 15$ at the most exspenive place around and 30 minutes of labour. all of mine are just about burnt but i didnt feel like buyin the connectors so i just reused them when i relocated ym controller to the driverside fender.............Gibson
D.T.Gibson
1.830.203.1460
new newer rig: '05 greyish/balckish Ford F-350 XLT Lariat, Crew Cab, 6.0L PowerStroke, Fx4, Leather and all the electric goodies besides a moon roof, auto trans, 3:73's, leveling kit. SCT Looney Tune stacked with Edge Juice with Attitude, and 4" turbo back exhaust. 91K.... blew HPOP and headgaskets. In shop for now. maybe by the 8th ill have her back with new long block! sweet!
newer rig: late '99 Red Ford F-350 PowerStroke, 4x4, CC, 4r100 Auto Trans, 3:73's, Stage Coach Conversion, 4" DP to 5" up to 6" stack, aFe Stage II intake, DP Tuner 4pos chip, dFUSER oil crossover line, 10K mod, AIC controller, '06 18" King Ranch Wheels. 225K.
new rig: CUMMINS POWERED '95 F-350 XLT, crew cab, Blue & white, ZF5-speed, 4x4 with auto locking hubs, 4:10 gears, 283K miles, 3" DP to 5" exhaust, Auto Meter A-pillar 3-gauge pod with EGT, Water temp and oil pressure.
Gibson is offline
post #5 of 7 (permalink) Old 06-28-2005, 11:58 PM
cdnsarguy's Avatar
My Photos: (109)
Most of us just put heat shrink over the bare metal connector. Ensure the HS is longer than the metal so shorting is not a problem when removed from GP and someone turns on the key.........
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #6 of 7 (permalink) Old 07-13-2005, 03:25 PM
Replacing the $325.00 (Ford Dealership Cost)Glow Plug wiring harness is generally the result of broken connection caps. A standard home Air Conditioner Compressor replacement (screw-on) electrical replacement terminal lug will also fit a Glow Plug tip and costs about $2.00. These are available at any Heating and Air Conditioning supply house. Admittedly, they have signs that they sell only to Contractors. However, you will probably receive a sympathetic ear from the Counter Person. Skin back the wire to a clean section, attach it to the after market replacement lug, tighten it down and repairs are complete. A little electrical tape for insulation purposes probably wouldn't hurt.
Good Hunting,
exsubchief is offline
post #7 of 7 (permalink) Old 07-13-2005, 08:59 PM
cdnsarguy's Avatar
My Photos: (109)
You can go here and buy a new one pretty cheap, it does have some extra wires but they can be removed by opening the loom.
http://www.shopdiesel.com/index.cfm/...ory_id/174.htm
