Old 10-22-2005, 03:02 PM   #1 (permalink)
glow plug question
Hi guys , just curious if you guys could comfirm the torque spec on our glow plugs the ford garage told me 14ft/lbs. thanks jason
chas010 is offline
Old 10-22-2005, 03:19 PM   #2 (permalink)
My Photos: (23)
Re: glow plug question
12 ft/lbs is the correct torque
Frank
Unofficial BOOB man (unofficial BUTT division: brotherhood of un-turboed trucks)
meet Big Black, my 1992 International 3/4 ton pickup wrapped in a Ford skin: 2wd, LWB, N/A 7.3, ZF5, 3.55s. 249k miles.
Amsoil bypass & AF. 3" true duals. no soup for me. 'ghetto' fresh air. Baja block drains. bottle broke. slobber tube. true dual 3" straight pipes. now a TRUE oil burner - she's drinking 15% Bunker Fuel (WMO).
soulpatchfr is offline
Old 10-22-2005, 05:45 PM   #3 (permalink)
What happens if you tighten it to 25 or 30 Lb.ft. I did one that tight by accident and it felt like I was on the verge of stripping.
Figure if I have to take it out, I better plan on replacing that one.
Diving Doug driving a 92, F-350, Std 7.3 Disel, 4WD, 5 Speed Manual, Std Cab, Black, ~110k miles, A New York truck by origin, came south w/ it's original owner and bought by me w/ 104k. Have rebuilt starter, replaced tires, batteries, and filters w/ a K&F air filter & stock fuel filter. Replace Glow Plugs and GP Relay.
F350Driver is offline
Old 10-22-2005, 05:48 PM   #4 (permalink)
Man, I would take that one out ASAP. I hear glowplugs can brake off easily (non for me yet, knowck on wood). At LEAST back it off to 12 ft-lb. I remember how hard mine came out and I torqued them myself. Heat has a funny way of REALLY making things hard to take apart.
-Luke
Rusty Red: '93 F-250 XLT xtra cab long bed. 3.55 rear end, 5 spd, 285/75/16 BFG All Terrains, 215,000 miles. Soup bowl chopped, K&N Air Filter, lots of rust.
85 Mercedes Benz 300D Turbo Diesel. 215,000+ miles (intermittant odometer), almost everything works (give me time), and $500!
Bigger Diesels:
-Sulzer 7RLB90, loop flow, fully ported (no valves), contant pressure twin turbo, cross-head 2 stroke, slow speed Diesel. 90cm bore, 210cm stroke, 28,000bhp @ 102rpm
-MaK 6M601, 4 stroke medium speed inline 6, bedplate construction, pulse turbo, 8,046bhp @ 475rpm.
-MaK 332 inline 6, pulse turbo medium speed inline 6, 900kW Gensets
-MAN B&W 6H28/32L inline 6, medium speed 1000kW Genset.
damonite is offline
Old 10-23-2005, 08:12 PM   #5 (permalink)
I thought i read on here 12ft/lbs thanks for the clarification guys, it was a miserable job (1990 e350 cube) i could barely get the air cleaner off! I couldnt see the front cylinders and i hope i didnt get any crud down the holes but..anyway i noticed im going to need a fuel return line kit soon for the hoses were looking cracked and dried, also i had to remove the steel lines on top of a few of the injectors is this going to cause any leak problems (air or fuel)? i wasnt sure if there was any type of o-ring to seal that cap. by the way i changed out my glow plugs after cheking one to find out it was a champion and pitched them in favor of the motorcrafts.
thanks for all the help so far jason
chas010 is offline
Old 10-23-2005, 09:49 PM   #6 (permalink)
quite possibly, put the peddle to the floor and crank it up and check for leaks. If you devolop a starting problem thats probably what it is.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
