Old 05-04-2005, 07:18 PM   #1 (permalink)
glow plug relay
Need to bypass my glow plug relay, I know how to do ti on a 6.9, how do you do it on a 7.3.
1991 F350 Diesel , axle 73, 4:10 rear end, 40D Trans, Crew Cab, Truck runs strong, don't smoke.
keliiaukai is offline
Old 05-04-2005, 09:12 PM   #2 (permalink)
My Photos: (17)
Re: glow plug relay
On the gp Relay there is a small white wire on a small terminal. Connect another wire to the same terminal, then to one side of your MOMENTARY switch, from the other side of MOMENTARY switch to ground and you're set. Hold MOMENTARY switch 8-10 seconds then fire it up. <font color="red">Do not use a regualr switch because if it gets left on or accidently switched on by you or someone else it WILL burn/swell up the plugs and then you'll have a REAL problem!!!</font> [img]/ubbthreads/images/graemlins/crazy.gif[/img]BajaGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 05-04-2005, 09:42 PM   #3 (permalink)
Re: glow plug relay
Do you have pictures of wireing, where is momentary switch, I don't know anything about 7.3, I had a 6.9 before I got my 7.3. 1992 F-350 duelly, crew cab.
Old 05-04-2005, 10:38 PM   #4 (permalink)
Gibson's Avatar
Re: glow plug relay
I did this mod. today as a matter of fact. [img]/ubbthreads/images/graemlins/wink.gif[/img] its very easy to do. heres a few steps i took.............Gibson
1) take the airfilter housing off
2) take the plasctic cover off the controller (says: do not
jump start here)
3) located the white wire
4) disconnect white wire
5) connect some wire to the spot where the white wire was
6) run that newly placed wire into the cab and up the dash to a
push button switch (ignition switch) can be bought at AutoZone
or wally-world (connect that wire to the the accesory prong)
7) connect another wire to the "power" prong on the switch
8) run that wire out the cab and to the Pos. (+) battery terminal
9) put a 15 amp fuse between the batetry and switch as for
protection against blowing your controller up.
D.T.Gibson
1.830.203.1460
new newer rig: '05 greyish/balckish Ford F-350 XLT Lariat, Crew Cab, 6.0L PowerStroke, Fx4, Leather and all the electric goodies besides a moon roof, auto trans, 3:73's, leveling kit. SCT Looney Tune stacked with Edge Juice with Attitude, and 4" turbo back exhaust. 91K.... blew HPOP and headgaskets. In shop for now. maybe by the 8th ill have her back with new long block! sweet!
newer rig: late '99 Red Ford F-350 PowerStroke, 4x4, CC, 4r100 Auto Trans, 3:73's, Stage Coach Conversion, 4" DP to 5" up to 6" stack, aFe Stage II intake, DP Tuner 4pos chip, dFUSER oil crossover line, 10K mod, AIC controller, '06 18" King Ranch Wheels. 225K.
new rig: CUMMINS POWERED '95 F-350 XLT, crew cab, Blue & white, ZF5-speed, 4x4 with auto locking hubs, 4:10 gears, 283K miles, 3" DP to 5" exhaust, Auto Meter A-pillar 3-gauge pod with EGT, Water temp and oil pressure.
Gibson is offline
